URGENT HELP: Shells with PSCREATE CAVER Values
Old   January 12, 2006, 05:18
Default URGENT HELP: Shells with PSCREATE CAVER Values
starcd_learner
Hello, i have a deformable mesh, transient case ie. many pstt files. At the moment i do not have ENSIGHT and through STAR-CD forum hints i create shells at one plane S1 i am interested in, then average scalar quantity with CAVER and then use PMAP to map on S1. I then output on file star.plot then go back and do cset news shells S1 cdel cset ccom all vcom all ctdel all and continue for next time step. I do the ccom all and vcom all for using as little memory as possible. Is this procedure right? Am i getting the CAVER data for each time step correctly or somehow faking something, specially considering it is a deformable mesh? I am unsure therefore please help. Thank you starcd_learner
Old   January 18, 2006, 22:14
Default Re: URGENT HELP: Shells with PSCREATE CAVER Values
steve
It sounds right to me. I don't know why you need to delete and recreate the shells each time. You can either leave them or move the vertices with out having to delete everything but it doesn't hurt. You do realize that all CAVERAGE does is take cell centroid data and average it to the vertices to produce smoother plots? If you have moving grid data make sure you reconnect up to the event file so that the vertices/cells are moved in post-processing exactly like the solution run.
Old   February 1, 2006, 10:03
starcd_learner
thank you, in my particular case, through a fluid-structure-coupling i dont have any event file.
very urgent pleasade:Cl and Cd values for airfoil Liaquat FLUENT 2 April 27, 2006 12:20
projecting on shells guest7777 Siemens 2 April 4, 2006 08:45
my pro-am shells Ted Crilly Siemens 3 February 15, 2005 18:21
Shells azmir Siemens 7 August 17, 2004 00:33
filling of elastic shells Nina Shokina Main CFD Forum 0 December 11, 2001 01:54
