January 17, 2006, 12:14 |
molecular properties
I tried to have the water density changing with both temperature and pressure, and so took the user database values. However, it says "insufficient dimmension for the molecular viscosity array". I solved the problem NCMAXV into NCMAX and all the others datas to be able to run the analysis. However, after I did it, the ouput given in a transient mode is absolutely wrong!! The density of water remains constant and equal to 1.2kg/m3 !!! What can I do? Is the user database wrong? It however looks right when we edit it!! Thank you in advance in you have a hint. Yann
January 18, 2006, 05:36 |
Re: molecular properties
Just a guess: Have you changed the cell material after defining a new material? Do you use liquid water or water vapour? How do you calculate the density?
January 18, 2006, 07:21 |
Dear Mork, that is effectively the first question to as, but yes, the cells are defined as liquid, and I am using liquid water. I am using the option: select material from database, then water(l), and then I tried to use "use internal properties calculation" which tells that the dimension array for viscosity is insufficient. What can I do? Create my own database? I also tried to use isobaric properties, defining the datum pressure as 997kg/m3, but the density doens't vary neither. Regards, Yann
January 18, 2006, 08:11 |
When you have changed your set up, do you re-write the .geom file (to get a new parm.inc) and re-write the .prob file?
January 18, 2006, 11:52 |
Thanks Richard,but yes I did rewrote both of them. Redards, Yann
January 18, 2006, 18:17 |
Are you using VOF? In that case you can only have constant densities for both fluids.
January 19, 2006, 04:33 |
Dear all, I resigned from my first idea to have the internal value for the water density. These value seem to be wrong...? I simply used the isobaric density for the water which is however less far convinient for the model I have to make. Anyway, thank you all for you help, and if ever someone knows the clue... Yann
Unit of Molecular weight | clark | FLUENT | 2 | March 15, 2008 05:28 |
How get Species Molecular Weight in UDF | hesam | FLUENT | 1 | April 14, 2007 18:55 |
Molecular Weight | Ari | FLUENT | 0 | August 22, 2004 07:36 |
Microscale CFD and molecular dynamics | Robert H. Leyse | Main CFD Forum | 2 | April 4, 2003 11:03 |
AIR molecular properties | Julie Polyakh | Siemens | 3 | January 5, 2002 16:25 |
