Prosurf to Proam problems, help please
Old   January 23, 2006, 10:03
Default Prosurf to Proam problems, help please
William Wallace
Hello everyone, I'm currently a student at university doing my final year project on the analysis of an engine intake system, basically its a mid engined supercar and my aim is to analise it in the current forum both in the wind tunnel and in CFD then redesign it and compare results.
Ok now I'm very new at using this software (V3.150A) and am having trouble importing the files from prosurf into proam. On importing the iges file into prosurf there are obviously a lot of errors. I've ran auto repair varying the tolerances until the errors are at the minimum amount that I can get them to. My problem is that I still have 199 free curve errors but when I generate the surface grid no errors are shown other than the curve errors.
Here's a grab of the model prior to the grid
http://img.photobucket.com/albums/v8...0/prosurf1.jpg
And after the grid
http://img.photobucket.com/albums/v8...0/prosurf2.jpg
Now I save the prosurf files as prostar .vrt and .cell files but when I go to import them into Proam the screen just goes white and displays the following in the output window;
PRO *> !************************************************* **********!
PRO *> !* *!
PRO *> !* PROSTAR INITIALIZATIONS: FILE PROINIT *!
PRO *> !* *!
PRO *> !* THIS FILE CONTAINS ALL COMMANDS RUN BY PROSTAR ON *!
PRO *> !* STARTUP. *!
PRO *> !* EDIT THIS FILE TO INCLUDE/EXCLUDE COMMANDS AS *!
PRO *> !* NECESSARY *!
PRO *> !* PRO *> !************************************************* **********!
PRO *> !
PRO *> !OPEN NOVICE PANEL
PRO *> OPANEL,TOOL ENTER A TOOL NAME
OPAN*> EASY
PRO *>
PRO *> no library has been specified for Tcl on line 1 in init.tcl dbase,open KZ1 Air Intake.dbs
AMM *> dbase,list
AMM *> tcl,done
AMM *> tcl,done
AMM *> tcl,done
AMM *> tcl,done
AMM *> tcl,done
AMM *> view,1,1,1
VIEWING DIRECTION FOR PLOT IS: 1.00000 1.00000 1.00000 IN GLOBAL COORDINATE SYSTEM
PLOT*> MEMOR MAXBRK 30000$MEMOR WRITE **NOTE - ALLOCATING MEMORY **NOTE - CHANGED PARAMETER MAXSC1 FROM 360000 TO 3002148 **NOTE - CHANGED PARAMETER MAXINF FROM 1252433 TO 1724357 **NOTE - ALLOCATING MEMORY **NOTE - CHANGED PARAMETER MAXSC2 FROM 2516915 TO 3460762 **NOTE - CHANGED PARAMETER MAXBRK FROM 3558 TO 30000
PRO *>
WROTE CURRENT PARAMETERS TO FILE param.prp OLD param.prp MOVED TO param.bak
PRO *> *IF DEBUG NE 1$OFILE,"./tmp/IMPORT_LOG.TMP"$*ENDIF $! SUPPRESS OUTPUT
PRO *>
PRO *>
PRO *> ! SUPPRESS OUTPUT
PRO *> safety error off
PRO *> tcl,done
AMM *> close, ./KZ1 Air Intake.cel
PRO *> plty,ehid$light 1 on center
PLOT*>
PLOT*> plme,on
PLOT*> window 0,0,15,15$pldi,off,info$lswitch shade
PLOT*>
PLOT*>
PLOT*> clrmode reverse
PLOT*> vstyle,3,6,0
PLOT*> zoom,off
PLOT*> angle,,
PLOT*> cdis,off,all
PLOT*> direction read
CONV*> *get mxco mxce
CONV*> cset,,$vset,news,cset$*get mxve mxve
PLOT*>
PLOT*>
PLOT*> cread "./KZ1 Air Intake.cel" mxve,,,add,Coded,,50
MESH*> vread "./KZ1 Air Intake.vrt" mxve,,,Coded
MESH*> *get mxce mxce
MESH*> cset,news,,mxco + 1,mxce
PLOT*> *IF DEBUG NE 1$OFILE NONE$*ENDIF $! SUPPRESS OUTPUT
PLOT*> clrp 20 1000 nplot clrt geom 1 1,1,1 clrt geom 2 1.,0,0 clrt geom 3 0,1,0 clrt geom 4 .0,0,1 clrt geom 5 1.0,0.5,0.0 clrt geom 6 0.7,0.5,0.7 clrt geom 7 0.9,0.8,0.5 clrt geom 8 0.5,0.5,0.7 clrt geom 9 0.5,0.7,0.5 clrt geom 10 0.55,0.5,0.5 clrt geom 11 0.7,0.5,0.5 clrt geom 12 0.,1.,1. clrt geom 13 1.,0.,1.0 clrt geom 14 1.,1.,0 clrt geom 15 0.5,0.5,0.9 clrt geom 16 0.5,0.92,0.7 clrt geom 17 0.8,0.9,0.8 clrt geom 18 0.7,0.6,0.7 clrt geom 19 0.57,0.8,0.9 clrt geom 20 0.7,0.3,0.38 lmat,1,.2 ofile,screen OUTPUT SWITCHED TO SCREEN
PRO *> safety error on ERROR LISTING WILL BE SUMMARIZED
PRO *> close "./tmp/IMPORT_LOG.TMP" FILE ./tmp/import_log.tmp CLOSED
PRO *> batch,on BATCH MODE TURNED ON
PRO *> count,cell
NO CELLS DEFINED
UTIL*> batch,off BATCH MODE TURNED OFF
PRO *> tcl,done
AMM *> tcl,done
AMM *> pltb,on PLOT IN BACKGROUND THEN POP TO DISPLAY
PLOT*> cplot **WARNING - NO CELLS SELECTED FOR PLOTTING **ERROR - NO ITEMS SELECTED FOR PLOTTING
PLOT*> pltb,off PLOT DIRECTLY TO THE DISPLAY
PLOT*> tcl,done
AMM *> tcl,done
AMM *> setw,IMPORTSET.TMP,1 WRITING CURRENT SET DATABASE TO FILE importset.tmp WITH IDENT= 1 WRITE COMPLETED
UTIL*> close,all FILE ./kz1 CLOSED
PRO *> tcl,done
AMM *> tcl,done
Sorry to bombard you guys/girls with all this info but I thought it would give a better indication where I'm going wrong. I'm running 32 bit windows XP.
Regards
William Wallace
Old   January 25, 2006, 14:01
Default Re: Prosurf to Proam problems, help please
Fr Ted Crilly
sorry dude, not sure if this will help but in my experience you are better get rid of all the warnings and errors that pro-surf reports before going to pro-am,
i would go back to your original starting iges geometry and fix any problems.
Old   January 25, 2006, 19:26
William Wallace
Yeah I understand what you're saying but whats the best way of getting rid of the 199 free curve errors without distorting the overall profile of the CAD model.
Thanks for the reply
Will
Old   January 26, 2006, 12:57
William Wallace
Can I also ask what exactly is a free curve error, I think if I have a better understanding then it may help. I've looked in the manual but can't seem to find an explanation.
Regards
Will
Old   January 26, 2006, 14:06
William Wallace
Heres an update, I've created a model using Pro E and saved as an iges file then imported it into prosurf and it isn't showing any errors at all. So I save the prostar files. Then when I go to import the .cel and .vrt file into proam its still saying
**ERROR - NO CELLS DEFINED IN MODEL and MAXIMUM CELL NUMBER IS NOW 0 MAX VERTEX IS NOW 0
So I'm assuming that I'm doing something very wrong?
Regards
Will
Old   January 26, 2006, 14:52
Tom
When you export the prosurf model it writes it as a proam dbs (1 if I remeber correctly). Just go to the database files in the proam GUI, and open it. Tom
Old   January 27, 2006, 04:27
azmir
Are u sure u saved as .vrt and .cell ? As I see here on my pro-surf, we can only export it as .dbs or .iges only (version 3.24). Then when u import in proam the .dbs file, u have to change the DBID somehow. There is a bug in that box. The default DBID will yield nothing on screen. Change that value and u will get it.
Old   January 27, 2006, 06:01
William Wallace
The way I save the file is by going to file then save prostar files, this allows you to save the cel and vrt files.
I've got a feeling that when I'm saving the iges file I'm not selecting the right options?
Does anyone know what options I should select when saving the iges file in Pro E?
This has got to be the problem. I'm going to try a few different options to see if anything changes.
Thanks for everyones input so far.
Will
Old   January 30, 2006, 19:01
ted crilly
i use catia solids export function for iges and it usually works well, when you use prosurf to initally surface mesh your iges geometry you output it to native star-cd format , i.e. prosurf_output.dbs, then open es-aero or pro-am in import star-cd native database it the last one on the list then select the prosurf_output.dbs and hey presto you can then use pro-am or es-aero to build a decent working mesh.... if your lucky, i find alot of bugs with es-aero in win xp and star cd 3.26 and some manual manipulation of ammbatch commands in dos shell necessary
Old   January 31, 2006, 01:38
yogesh
I think the best way is to clear all the cad errors in prosurf and write proam (.dbs) file and import it in proam it work may time for me
Old   January 31, 2006, 21:30
  #11
tak
hi william
even my suggestion is try to have a good cad model i mean IGES/IGS file ...and using prosurf repair options hope we can overcome from free curves ..and once u have a surface mesh /triangulated mesh ..save it in proam DBS format instead of prostar CEL and VRT format. still if u have any free edges/ curves etc ..u can clear these errors using proam surface cleaning options ..wish u all the best
regards anand
Old   February 3, 2006, 17:00
  #12
William Wallace
Well I finally got the file imported into Pro-am even when it still had free curve errors. What I did was to clear my working directory completely then put just the iges file into it. I then set it again as my working directory, imported the iges file into Pro-surf and repaired as best as I could then tried to import it into Pro-am and it worked fine. I honestly couldn't believe it, thanks to all your advice it's been very much appreiciated.
Kind regards
Will
iges-prosurf-proam-prostar-star elvis Siemens 6 October 17, 2005 04:35
Prosurf in batch mode Dhruv Siemens 1 September 19, 2005 18:02
ProSurf JBS Siemens 2 March 23, 2005 03:58
proam sankar Siemens 0 February 23, 2005 04:58
proam problems beastberg Siemens 1 April 25, 2004 06:33
