Home > Forums > CD-adapco
Simpler Chemical Reaction Problem
Old   February 2, 2006, 17:13
Default Simpler Chemical Reaction Problem
Sam
I have the following problem. Main gas stream is Air with a 30 PPM (parts per million by volume) of SO3 at the inlet. I'm injection NH3 downstream of the inlet. The chemical reaction is NH3 + SO3 + H2O --> NH4HSO4.
The reaction is temperature dependent but instantaneous. I don't know the reaction constants. Is there are way to combine the intesections of the scalars of SO3 and NH3 and H2O to form a new scale of NH4HSO4? Or, how do I model this chemical reaction. I'm new to this.
Thanks for the help.
Sam
Old   February 3, 2006, 10:36
Default Re: Simpler Chemical Reaction Problem
Guillaume
It seems you want to use a `mixed-is-burned' model, don't you?
You have to define three passive scalars with the same transport equation than NH3, SO3 et H2O respectively. It gives you the concentration of these reactants if there were no reaction. You can thus determine which one would be in default and deduce the effective concentration of NH3, SO3, H2O and NH4HSO4 on a cell-by-cell basis.
In Star-CD, use the sorsca.f exemple coding to impose this effective concentration. The 'chemico-thermal' enthalpy option should give you the temperature from the concentration field.
What do you mean by `the reaction is temperature dependent but instantaneous'?
Old   February 3, 2006, 10:43
Sam
"Mixed is burned" is correct. For our purposes the reaction is instantaneous. By temperature dependent I mean that the reaction will not occur below a certain temperature. I'd like to see the three passive scalars enter the domain, the reacted scaler where the temperature is above a certain T_act, and the remining reactants scalars.
Will Star automatically create the 4th scalar when I set up the reaction? I'm looking at the methodology volume and I believe I want to use the EBU model.
I'm not familiar with the sorsca.f coding. Is there anywhere that I can learn more about this? Does the sorcsa.f coding eliminate the need to model the chemical reaction?
Old   February 3, 2006, 14:48
Guillaume
The reason I spoke about sorsca.f is that you have to implement the combustion model by yourself. EBU is not 'mixed-is-burned'.
You have to define all the scalars (reactants, products and passive scalars) + the background medium properties.
sorsca.f is described (a bit) as any other user routines in Chap. 18 of the user's guide (`USER PROGRAMMING'). When this routine is written down, you will have sample coding.
Otherwise, you may run the `EQUILIBRIUM CHEMISTRY MODEL' with `MULTIPLE FUELS' but you will have few control as it is an in-build feature. On the other hand, it does almost everything for you. You still have to define reactants and background fluid. Furthermore, the flow has to be turbulent, is it the case?
Old   February 3, 2006, 15:01
Sam
How do I implement the Equilibrium Chemisry Model? Is it in the GUI?
Old   February 6, 2006, 10:24
Guillaume
It is in the GUI. Check the user's guide.
Old   February 6, 2006, 14:28
Sam
Okay. I have implemented the reaction. Again the original equation is NH3+SO3+H2O = NH4HSO4. When I set up the reaction a N2 scalar is setup. I set up the inlet as 95% N2 and 5% H2O and 30 PPM SO3. However, when I plot the N2 scalar it is not constant in the entire domain. It is reacting as well. Is there any reason for this. I only want the scalars in the reaction to show any change in concentration.
Old   February 7, 2006, 10:28
Guillaume
If star predicts a reaction, there should be a reaction.
If you do not want it, create a virtual N2, VN2, and assign to him the same properties as N2.
Thread Tools
Trackbacks are On
chemical reaction problem Benoit FLUENT 2 March 14, 2013 15:56
CFX5.7 - chemical reaction problem... H.L. CFX 4 March 25, 2009 11:33
Chemical Reaction Lokesh CD-adapco 0 October 6, 2008 16:27
Problem about water spliting chemical reaction !! Luke FLUENT 5 June 12, 2006 23:26
turbulent mixing controlled reaction vs. chemical kinetics controlled reaction Hyeryung NA Main CFD Forum 10 November 11, 1999 04:00
