February 16, 2006, 01:54 |
posdat.f Problems
I uses STAR-CD v3.26
When OPEN function is included, this kind of problem is occuring. If posdat.f is excluded, it is working very well without any problems ******************* posdat.f ************************* ~~~~~~~ abbrev.~~~~~~ IF(LEVEL.EQ.2) THEN IF(INTFLG(1).EQ.0) THEN OPEN (84,FILE='MonP.dat',FORM='FORMATTED',STATUS='UNKNO WN') ==> Error position!!! DO I=1,INUMBER DO J=1,NCTMXU IF(IPROSTAR(I) .EQ. ICLMAP(J)) THEN ~~~~~~~ abbrev.~~~~~~ ************************************************** ***** ******************* Running ******************************** 1 5.40E-01 3.13E-01 1.33E+00-1.01E-04 1.40E-05 1.27E-02 1.47E+08 -1.06E-03-1.51E-03 6.03E+00 2.02E+00 6.84E-01 1.92E+01 1.94E+03 -1.97E-07-5.33E-06-3.42E-06 3.58E-07-8.40E-06-7.34E-05 0.00E+00 4.19E-03 6.44E-02 6.35E-05 2.06E-03 9.86E-02 7.18E-01 0.00E+00 -1.60E-05 0.00E+00 0.00E+00 0.00E+00 0.00E+00 0.00E+00 0.00E+00 1.78E-01 0.00E+00 0.00E+00 0.00E+00 0.00E+00 0.00E+00 0.00E+00 [ 1 ] ***Received signal sigsegv - exiting PNP: Shutdown [2006-02-16-04:13:15] Execution aborted by request (SIGABRT) after 9 seconds (TOTAL ELAPSED TIME). 1060% [kris@node01 transient]# ************************************************** **** |
February 16, 2006, 12:05 |
Re: posdat.f Problems
It's not easy to see the problem because you only put part of your code, try this IF(LEVEL.EQ.2) THEN
IF(INTFLG(1).EQ.0) THEN OPEN(84,FILE='MonP.dat',FORM='FORMATTED',STATUS='U NKNOWN') INTFLG(1)=1 ENDIF ..... |
February 20, 2006, 02:42 |
in this code
If OPEN command is NOT included, No Error occures. If OPEN command is included, Error occures and the result is as follow ******************* Running ******************************** 1 5.40E-01 3.13E-01 1.33E+00-1.01E-04 1.40E-05 1.27E-02 1.47E+08 -1.06E-03-1.51E-03 6.03E+00 2.02E+00 6.84E-01 1.92E+01 1.94E+03 -1.97E-07-5.33E-06-3.42E-06 3.58E-07-8.40E-06-7.34E-05 0.00E+00 4.19E-03 6.44E-02 6.35E-05 2.06E-03 9.86E-02 7.18E-01 0.00E+00 -1.60E-05 0.00E+00 0.00E+00 0.00E+00 0.00E+00 0.00E+00 0.00E+00 1.78E-01 0.00E+00 0.00E+00 0.00E+00 0.00E+00 0.00E+00 0.00E+00 [ 1 ] ***Received signal sigsegv - exiting PNP: Shutdown [2006-02-16-04:13:15] Execution aborted by request (SIGABRT) after 9 seconds (TOTAL ELAPSED TIME). 1060% [kris@node01 transient]# ************************************************** **** POSDAT.F Test Source file !************************************************* ************************ SUBROUTINE POSDAT(KEY,VOL,U,TE,ED,T,P,VIST,DEN,CP,VISM,CON, * F,ICLMAP,ICTID,RESOR,VF,FORCB,IRN,PREFM,LEVEL) !C Post-process data !C************************************************ ************************* !C--------------------------------------------------------------------------* !C STAR VERSION 3.20.000 * !C--------------------------------------------------------------------------* INCLUDE 'comdb.inc' COMMON/USR001/INTFLG(100) DIMENSION KEY(-NBMAXU:NCTMXU),VOL(NCTMXU),U(3,-NBMAXU:NCMAXU), * TE(-NBMAXU:NCMAXU),ED(-NBMAXU:NCMAXU),T(-NBMAXU:NCTMXU,1+NSCU), * P(-NBMAXU:NCMAXU),VIST(-NBMAXU:NCMAXU),DEN(-NBMAXU:NCTMXU), * CP(-NBMAXU:NCTMXU),VISM(-NBMXVU:NCMXVU),CON(-NBMXCU:NCMXCU), * F(3,-NBMAXU:NCMAXU),ICLMAP(NCTMXU),ICTID(NCTMXU), * RESOR(89,-100:100),VF(NCDMXU),FORCB(3,NWLMX),IRN(NWLMX) DOUBLE PRECISION P DOUBLE PRECISION T DOUBLE PRECISION TE DOUBLE PRECISION ED DOUBLE PRECISION U DIMENSION PREFM(4) INCLUDE 'usrdat.inc' DIMENSION IPROSTAR(100),ISTAR(100),IBOOL(100) DATA IPROSTAR/100*1/ DATA IBOOL/100*0/ DATA ISTAR/100*1/ IF(LEVEL.EQ.2) THEN IF(INTFLG(1).EQ.0) THEN OPEN(84,FILE='MonP.dat',FORM='FORMATTED', STATUS='UNKNOWN') CLOSE(84) 700 FORMAT(A8,1P,I20,I20,I20,I20,I20,I20,I20,I20,I20,I 20,I20 * ,I20,I20,I20,I20,I20,I20,I20,I20,I20,I20,I20) 800 FORMAT(F10.8,1X,E20.13,1X,E20.13,1X,E20.13,1X,E20. 13, * 1X,E20.13,1X,E20.13,1X,E20.13,1X,E20.13,1X,E20.13, 1X,E20.13, * 1X,E20.13,1X,E20.13,1X,E20.13,1X,E20.13,1X,E20.13, 1X,E20.13, * 1X,E20.13,1X,E20.13,1X,E20.13,1X,E20.13,1X,E20.13, 1X,E20.13) ENDIF ENDIF RETURN end |
Display Modes | |
CFL in posdat | hamodi | Siemens | 2 | August 6, 2007 03:27 |
posdat.f - other problems | kris | Siemens | 0 | February 24, 2006 02:05 |
POSDAT | Sheila | Siemens | 2 | February 8, 2006 12:08 |
posdat in HPC | Won-Geun Lee | Siemens | 0 | May 23, 2001 21:03 |
Posdat | Maria Carlsson | Siemens | 1 | April 30, 2001 11:29 |
