February 16, 2006, 04:45 |
create moving mesh
I'm a new user. I want to use a moving mesh. I did it step by step in the tutorial. In one step, I don't understand and can't do it,that is creating case.cgrd. Please tell me how to do.
February 16, 2006, 13:17 |
Re: create moving mesh
Which tutorial?
February 17, 2006, 06:23 |
tut7.1 tut7.2 tut7.3 tut7.5
February 17, 2006, 20:51 |
tut 7. I did it but when I checked moving mesh, it doesn't move. I don't know what's wrong. Please tell me step by step or teach me your caes study that is easier than tut 7. thank you
February 20, 2006, 09:59 |
Some versions of star are simply unable to process the moving mesh. This bug is, for instance, present in 3.15B. In 3.2, some of the commands are not recognized and in 3.24, long scripts cannot pass.
It is thus hard to say, a priori, whether you made mistake or whether you experience one of these bugs. What I do in such cases: I copy the tutorial case from the installation directory into a working directory and I try to make the case provided by Adapco run (you have to import all the files and process a `tut.inp' before saving the case). If it runs, this is your mistake. I or others on this forum may be able to help you. If it does not run, explain your case to the technical support to get another version. You can do nothing by yourself. |
Display Modes | |
[Gmsh] Create Hex Mesh | fabrizio | OpenFOAM Meshing & Mesh Conversion | 9 | March 22, 2010 09:09 |
Create fine mesh that grows to coarse mesh (Urgent | CZ | FLUENT | 1 | January 3, 2009 10:36 |
Moving Reference frame - UDF - Moving mesh | modisa | FLUENT | 0 | April 18, 2008 13:31 |
how to create a moving mesh geometry in gambit | Kannan | FLUENT | 0 | December 15, 2005 11:03 |
Create the file of PROTEMP.PLOT during moving mesh | xhliu1 | Siemens | 2 | November 4, 2004 04:23 |
