too many walls??
Old   February 28, 2006, 14:14
Default too many walls??
matze
We have a little problem: Some of our geometries contains a hugh number of walls, eg. 3mio wall faces for 12 mio fluid cells. With some tricks we got the problem to run, but: the mass error grows, inlet and outlet are ok, but a few cells away from inlet all velocities are very small (~10e-6). When checking the results on the screen, the fluid seems flowing through the wall. Who knows this problem? Who knows who to fix it? Thanks to all,
Matze
Old   March 1, 2006, 06:52
Default Re: too many walls??
John Luo
Did you merge vertices in the model? You can issue "Vmerge ALl" in PROSTAR, then write out geometry again.
Old   March 1, 2006, 07:13
matze
The vertices are merged. I had a correct running model. Then I deleted some cells in the fluid volume to have some walls inside. Only this few (~50000) deleted cells and extra walls cause the problem.
matze
Use wall function on some walls (not all walls) Mahdi10 FLUENT 1 February 16, 2009 11:52
Droplets at Walls Elaine CFX 1 October 18, 2007 04:59
HTC for low Y+ walls Tang FLUENT 0 March 15, 2007 15:55
how to cluster walls prc Siemens 2 December 26, 2006 03:56
DPM statistics on walls olivia FLUENT 2 August 5, 2004 11:18
