March 13, 2006, 19:02 |
Boundary face 7
Dear all
When working with trimed cells, without subsurface, we often found a trimmed cell adjacent to the boundary. If the 7th face of that cell is a boundary face, it can not be good... Question: instead of remeshing, there anybody know the way to deal with it? Can we automatically rotate these cells in order to put the 7th face connected to the bulk cells? Regards |
March 14, 2006, 04:57 |
Re: Boundary face 7
From my understanding trim cell faces 7 and 8 are internally linked to other faces handeled as partial boundaries, so this should not make a problem if these faces are wall boundaries. But on the other hand you are right, you cannot have different boundary conditions on both linked faces. That is why you have sometimes problems with baffles or boundary conditions on certain trim faces
If you want to put other boundaries on these faces, there is no automatic method to 'rotate' the cells. There is a command cmrefine, which refines trimmed cells into regular cells with additional couples. On outlet boundries you could extrude one or more layers and put boundary conditions there. And the last possibility is to fix or rotate manually. Best regards, Oliver |
March 14, 2006, 19:41 |
Re: Boundary face 7
Many thanks for you answer.
zeman |
March 15, 2006, 02:50 |
Re: Boundary face 7
Actually this issue is covered in the User Guide (though it's not emphasized - in this case you have to extrude at least 2 layers of prisms. If your [former] boundary face has more than 4 corners then you'll have to divide "multi-vertex" prism you get there into "normal" 6-vertex prism and couple them to the initial face. Not sure that it can be done automatically, but probably CMREFINE with proper parameters will do the job.
[Gmsh] Boundary face | hsieh | OpenFOAM Meshing & Mesh Conversion | 1 | August 30, 2009 17:57 |
where is the origin of a boundary face for udf | ma jie | FLUENT | 1 | August 14, 2006 15:21 |
boundary condition of face for liquid and gas | Luke | FLUENT | 6 | May 21, 2006 13:45 |
Calling Viscosity on a boundary Face | DH | FLUENT | 0 | March 15, 2005 14:23 |
Boundary face | Alex | CFX | 2 | August 18, 2001 10:23 |
