Home > Forums > CD-adapco
heat release rate simulation
Old   March 6, 2006, 06:30
Default heat release rate simulation
chiang
Hai cfd experts
I am interested in calculating heat release rate using STAR-CD.If anyone have calculated the same please let me know.Thanks is advance.
chiang
Old   March 6, 2006, 20:55
Default Re: heat release rate simulation
kris
hi chiang
If you want to get a heat release, NEVER use STAR-CD
because you can not get it from *.pst file
Only you can get it using posdat.f subroutine
but you may experience complex problems in your coding
actually, I don't understant why there are not heat release in POST FILE of STAR-CD.
I was getting nervous due to heat release in 2004.
However, STAR-CD don't still accept opinion of USERS. :<
I recommand Fluent or CFD-ACD...
Old   March 7, 2006, 03:04
TomK
hhhäääääää??????
Old   March 7, 2006, 06:23
kris
if you calculate species, get a heat release(combustion), and then directly take contour on total computation domain, it is difficult due to only using subroutine (below 3.26) I dont know in above v3.25.
good luck
Old   March 7, 2006, 07:41
chiang
Thanks kris,but still I couldn't get it.Plz could you explain me in detail.
Thanks and Regards Chiang
Old   March 7, 2006, 09:44
kris
1. using post data when only using EBU, you can trace reversly to reaction rate to need to refer STAR-Cd methodolgy.
it is possible to get a reaction rate though process is complex :<
you get reaction rate using "oper" command, save reaction rate using "ofile" command, and then sort it through your fortran sorting code.
using EXCEL(MicroSoft), reaction rate * enthalpy(global reaction)=heat release rate
acutually, it's hard to explain only words, only you must look at the methology and then you can see this method.
2. using subroutine
you can use subroutine. I have been heard STAR-CD company send the sample source of posdat.f to customer.
you can contact cd-adapco. sorry...
I recommand Fluent if you want to get a heat release from combustion or chemistry calculation. I already comfirmed Fluent can do it.
good luck. I'm go to bed ..Zzzzzzz
Old   March 8, 2006, 01:14
chiang
Thanks a lot,kris.I'll try it.
chiang
Old   March 9, 2006, 08:18
Shan
Dear chiang,
For your information the Heat Release rate values for every crank angle is available in case_name.spd file written by STAR-CD after the combustion analysis.This file is available from 3.0 versions on STAR-CD but HRR values available only from 3.22 and advanced versions of STAR-CD.For further details refer user guide chapter 13 and page 9 under the topic Engine Combustion Data Files.
Old   April 16, 2006, 07:47
Default Re: heat release rate simulation *NM*
m saber
Thread Tools
Trackbacks are On
heat release rate in output file Caty CFX 6 June 16, 2014 11:06
heat release rate calculation Karthick .K FLUENT 1 February 27, 2014 20:55
Troubles with heat release rate Xavier Ponticq CFX 4 September 12, 2012 18:49
Diesel combustion simulation ( Heat release rate) venkatesh CD-adapco 2 April 29, 2009 07:38
calculation of heat release rate paul CD-adapco 3 February 16, 2006 04:40
