Error # 106
Old   March 6, 2006, 16:13
Default Error # 106
Konstantinos
When writing the geometry file I get this message:
Error # 106: Faces of couple are not close enough to be valid.
Does anyone know how I could fix this?
Thanks
Old   March 7, 2006, 06:32
Default Re: Error # 106
chiang
Hi
Increase the tolerance value and do couple again.
Regards Chiang
Old   March 7, 2006, 06:35
Konstantinos
Hi, how do I increase the tolerance value?
Old   March 7, 2006, 07:01
chiang
Hai
Go to Tool->Couple Tool->Edit Types->Partial Boundaries->on.There you can increase the tolerance value.
Reg, chiang
Old   March 7, 2006, 11:53
Konstantinos
Thanks, but it still doesnt work, even when i increase tolerance to 0.99!
Old   March 8, 2006, 04:46
Mork
Maybe you have generated couples where you shouldn't have. You could try deleting the couples and then check for cracks. If there are no cracks after deleting the faulty couples, you should be alright.
Old   March 8, 2006, 05:36
Konstantinos
I delete the couples from the couples tool, right? But how do I check for cracks?
Old   March 8, 2006, 06:39
Mork
Run the couples check with the option to put the faulty couples in one set. Then delete this couples set. You can do this with the couples tool. You can check for cracks with the check tool. Be aware that the crack check will take a while (how many cells does your model have?). Additionally you can check for cracks by inspecting the model in quick hidden line mode. Cracks will appear like floating walls inside your domain.
Hope that helps.
Old   March 8, 2006, 06:47
Konstantinos
The model is about 800000 cells! Ill try to do what u said! Thanks for ur advice it seems very helpfull!!!
strange fluent error: Primitive Error at Node 0 Jean-Baptiste FLUENT 8 June 14, 2022 11:11
error in COMSOL:'ERROR:6164 Duplicate Variable' bhushas COMSOL 1 May 30, 2008 04:35
"Error: Floating point error: invalid number" MI Kim FLUENT 2 January 4, 2007 10:00
Fatal error error writing to tmp No space left on device maka OpenFOAM Installation 2 April 3, 2006 08:48
Error: Floating point error: invalid number Bob FLUENT 3 June 3, 2005 18:11
