Home > Forums > CD-adapco
Making program run faster
Old   March 7, 2006, 09:12
Default Making program run faster
Konstantinos
Are there any easy alterations that u can do on a model so that the iterations rus faster? Because its moving really slow... Im using star-cd 3.26
Old   March 7, 2006, 10:09
Default Re: Making program run faster
Mork
Decrease the number of cells, use simpler or less models, buy more and faster computers....
What are you trying to do?
Old   March 7, 2006, 12:52
Konstantinos
Modelling the flow around a formula car... (Not a formula 1 obviously, its a formula student car). So i cant use a different model. Computers are quite fast because they r university computers! How do i decrease the number os cells?
Old   March 7, 2006, 23:29
Mac
You need to re-mesh the car model again, to decrease the number of cells.
Old   March 8, 2006, 06:09
John Luo
how many cells you are using. To simulate a 3D car body, it would be advisable to run in parallel mode using as many processors as you can grab. It is usually true if you use 2 processors, time reduced by half, and so on.
Old   March 8, 2006, 06:35
Konstantinos
Thanks!
Old   March 8, 2006, 06:39
Konstantinos
I dont know how many cells the problem is... Anyway I will try running it on two processors then, thanks!
Old   March 8, 2006, 06:53
matej
Konstantinos, obviously if you want some reasonable results, you NEED and MUST read something about CFD (you'll find some references in the CFD-onine book section situated on the top of this page - right hand side). Additionally you MUST check the manuals. I know its a lot of reading, but STAR-CD is not MS Excel. Wait for your advisor and make him to get the training for you.
good luck matej
ps: RTFM stands for 'read the f*** manual' ) which is usually good advice in 99% of cases
Old   March 8, 2006, 10:53
Zamir Rashid
Are you using tets or hex for the case?
If you're using tet mesh (as I always do) I think it would help to use the command TETALIGN ALL which will reorder the vertex numbering and increase uniformity for tet meshes. This in turn would help to reduce memory requirements and computer time.
Old   March 8, 2006, 12:58
Ben
I have to agree with matej unfortunately it seems that you dont know a great deal about the subject, "how can I make my simulation run faster" is in the same bracket of questions of "how many cells do I need", "how big should my cells be", "I am studying X and my results are wrong, why" and so on and so forth.......!
Thread Tools
Trackbacks are On
near wall faster azmir CD-adapco 0 December 26, 2007 20:36
Making SIMPLE converge faster Fabio Main CFD Forum 4 April 9, 2006 11:35
Fortran 90 faster than C/C++ B. R. Guirguis Main CFD Forum 48 March 6, 2006 14:49
MicroTunnel V1.2 - Now 6x faster! Axel Rohde Main CFD Forum 0 September 18, 2001 23:34
more RAM or faster CPU?? Fabrizio Grieco CD-adapco 11 January 23, 2001 08:35
