error 84 couple error
Old   March 8, 2006, 05:45
Default error 84 couple error
Tipakorn
How to correct error 84, master cell face in one couple is defined as a slave cell face in another couple. Thank you
Old   March 8, 2006, 05:47
Default Re: error 84 couple error
Mac
Delete the couple and redo the coupling with proper master and slave cells defined.
Old   March 9, 2006, 02:44
Tipakorn
Thank you, But I can't do it. Please tell me more detail.
Old   March 9, 2006, 04:53
Mork
You can control which cell is used as a master and which one as a slave by assigning different cell types. Use the couple tool for creating, checking, deleting couples.
Old   March 9, 2006, 05:52
tak
hi tipakorn
try with this option
in prostar - tools - couple tools go for couple check - use YES option at remove non overlapping slaves
this may help you ..all the best anand
Old   March 10, 2006, 01:47
Tipakorn
Thank you I used to do this but there are errors.
Old   March 10, 2006, 17:35
Paulh
It may be that the chunck of cells in question are just badly formed. Cut out the cancer and put something better in - make new cells and cpmatches.
strange fluent error: Primitive Error at Node 0 Jean-Baptiste FLUENT 8 June 14, 2022 11:11
Errors when Compiling UDF: error C2040/error C2099 Julian K. FLUENT 1 December 21, 2008 00:23
COUPLE ERROR star Siemens 3 May 17, 2007 05:19
Couple error Yehia Siemens 3 January 25, 2007 03:58
Fatal error error writing to tmp No space left on device maka OpenFOAM Installation 2 April 3, 2006 08:48
