Listing Average Results
Old   March 12, 2006, 10:22
Default Listing Average Results
Deepak
Hi
Can someone tell me how to list the average values for a plane (inlet and outlet) in star cd. I need the average values for total pressure and velocity magnitude for each plane, and all I am able to extract is the profile.
Thanks Deepak
Old   March 13, 2006, 08:53
Default Re: Listing Average Results
Zamir Rashid
One way to do this is by using the command INTEGRATE
example: get the results you want, say total relative pressure (getc all ptot rela) plot to show the contours (popt cont $replo) get a cross sectional view of the plane in question then choose section surface view (plty sect) change the view to normal view (view snorm) Now use the integrate command (inte cset) you will get a table like this (just an example):
NO. CELL TOT A TOT A*VN TOT A*S TOT A*VN*S 16722 1.91743 -.338276 -4.14201 0.717017
By dividing TOT A*S with TOT A, you will get the average value of the scalar in question, i.e. total pressure for this example. Hope this helps.
Old   March 14, 2006, 01:22
alyaskin@mail.ru
If you want something at the boundary, you can "order" these values in Engineering Data (see the corresponding panel)
how to convert 3d results in 2D results Ben CFX 1 February 18, 2009 16:42
RANS from time average -- How about space average? TT Main CFD Forum 1 April 11, 2006 14:38
Cd average value Giuseppe FLUENT 1 March 8, 2006 02:01
Roe average cfd student Main CFD Forum 0 February 16, 2004 00:22
SIMPLER (FORTRAN Listing) isbn001 Main CFD Forum 0 April 11, 2003 13:36
