Home > Forums > CD-adapco
projecting on shells
Old   April 4, 2006, 08:30
Default projecting on shells
guest7777
Hello, I want to project physical quantities on shells created by PSCREATE. The shells are not neat-looking in the sense there are a few which are too pointed or small. Is this a problem ? Due to the mesh geometry I have defined the planes with the command SNORM, vertex I,vertex II, vertex II and then used PSCREATE for the fluid cells around this section-plane. Thanks
Old   April 4, 2006, 08:43
Default Re: projecting on shells
TG
There is no problem with the shapes. Depending on whether your starting data is cell-centered or smoothed (vertex data) the projection will either use each shell centroid or each vertex. There is no use of their shapes in the process.
Old   April 4, 2006, 08:45
guest7777
To TG thank you very much.
Thread Tools
Trackbacks are On
projecting curved connectors to db in gridgen Mike Main CFD Forum 1 October 10, 2008 11:07
error in shells near the curves or edges Abhijit FLUENT 1 June 2, 2007 22:26
my pro-am shells Ted Crilly CD-adapco 3 February 15, 2005 19:21
Shells azmir CD-adapco 7 August 17, 2004 00:33
filling of elastic shells Nina Shokina Main CFD Forum 0 December 11, 2001 02:54
