April 6, 2006, 16:23 |
regarding to mass flow rate
Hai,i done moving mesh,now iam doing post processing.in post processing i face a problem in calculating mass flow rate in intake port i executed macro given in Dr post.it is giving different values at different placesses in port.the variation is too much ,it varies 62 to 210 kg/hr. please help me how to calculate mass flow rate. thank you siva
April 6, 2006, 17:54 |
Re: regarding to mass flow rate
I have used that macro several times and have only had the problem you describe when the mass flow has not converged. Sometimes all residuals will decrease except mass. How does your mass residual look?
Tom |
April 7, 2006, 01:53 |
thank you tom. Mass residual is increasing with crank angle,total mass traped is correct. can i know how much mass flow rate you got while executing the macro and where you are executed the macro ie at inlet boundary or middle of port or just above the valve portion. thank you siva
Display Modes | |
Mass flow rate of the DPM mass sourse ?? | Rhinocao | FLUENT | 3 | January 21, 2011 13:10 |
Mass Flow Rate!!! | haiduc | FLUENT | 1 | June 7, 2007 11:08 |
DMP mass flow rate | Don Parsons | FLUENT | 3 | April 17, 2007 03:30 |
Mass flux and mass flow rate | us | Phoenics | 10 | March 31, 2006 03:06 |
How are the mass flux and mass flow rate defined? | Miles | Siemens | 2 | November 7, 2002 09:45 |
