-   CD-adapco (http://www.cfd-online.com/Forums/cd-adapco/)
-   -   Multiple Frames- Explicit (error #099) (http://www.cfd-online.com/Forums/cd-adapco/55295-multiple-frames-explicit-error-099-a.html)
sham April 12, 2006 09:32
Hello erverybody, I have a question regarding Torque converter analysis. I have taken one sector from each of 3 components (Impeller, reactor &turbine). I have applied Inlet & Pressure boundary conditions at each component ends. And coupled these boundaries by regions. I tried to solve with explicit Multiple frames. For some reason it is giving Error #099. Please read following messege what I see every time I try to give a run.
*** ERROR #099 *** TANGENTIAL AREA > .005% FOR CELL 8960 FACE 2 TANGENTIAL AREA, TOTAL AREA, PERCENTAGE: -8.518357E-10 1.206000E-05 -7.063312E-03
It would be great, if someone could help me with this matter.
thanks
sham
John April 18, 2006 05:34
Re: Multiple Frames- Explicit (error #099)
In explicit multiple frames, the coupling boundaries should not have area component in the tangential direrction. In your case, it seems not too bad.
You can either correct your boundary mesh a little bit to make sure there is no tangential area or simply set Real Constant 68 to 1 to ignore the area check.
sham April 21, 2006 08:23
Thank you john it is working
bsbalachandran June 9, 2006 00:29
hello sham!
i am just going to start the torque converter analysis using starcd. since i am a new user to star cd, could u able to help me the procedure how to proceed.
if u have any particular tutorials please reference me..
with regards bala
Ashok Barik June 9, 2006 04:07
Two phase flow in a channel.
