backporting star4 cel/vrt -> star3
Old   April 11, 2006, 08:05
Default backporting star4 cel/vrt -> star3
Mark Olesen
Perhaps others have the same problem - exporting cel/vrt from Star-CD v4 into a form that can be read by older versions. Nastran/Patran export works somewhat, but has problems with pyramids etc.
I have a workaround (a perl program for converting the cel/vrt files). Since I cannot seem to attach the file without butchering all the lines, I'll send a copy to cd-adapco support - so you can also bug them for a copy of it.
/mark
usage:
star-backport [OPTION] file1 .. fileN
options: -h usage
Attempt to backport .cel/.vrt files from star4 to star3 format. The new names are prefixed with '__star3__' and suffixed with ''.
Unfortunately, cd-adapco provides no means for this.
Polyhedron and trimmed cells are not supported. Only the following cell types are attempted:
* hexa tetra prism pyramid (fluids and solids) * triangle quad (shells and baffles) * line and point
The program is provided as is, without warranty, of completeness, accuracy, usability, fitness for a particular purpose.
version 1.2 (2006-04-11) copyright 2006, Mark Olesen <Mark.Olesen@ArvinMeritor.com>
Old   April 12, 2006, 17:12
Default Re: backporting star4 cel/vrt -> star3
Yogurt
This is not bright at all and a totally pointless waste of time to say the least. Backward compatibility has never existed.
If a simulation has to be run into star 3, it should be created in star 3.xx or earlier version.
and then use upward compatibility if necessary.
"Don't-even-think-about-it" or "Dont'-even-go-there", as everyone says
you can see the consequence: "The program is provided as is, without warranty, of completeness, accuracy, usability, fitness for a particular purpose."
Old   April 13, 2006, 05:02
William Blake
What if you incidently save your v3 model when playing with v4 without having a backup? cdsave was always an option to go back to an earlier version, which doesn't work any more.
Old   April 13, 2006, 05:35
Mark Olesen
Assuming that 'Yogurt' is not simply trolling, despite the very distorted interpretation of the usual legal disclaimer, I'd like to respond.
The point of moderate backward compatibility is to recover mesh geometries from newer into older versions. Examples of such would be for benchmarking wall-functions and turbulence models between versions, particular customer requirements, or simply for other programs that do not yet support the new formats.
Old   April 14, 2006, 11:36
Raul
whimsical...
William Blake is right: it is by mistake
ARRAY PASSING in STAR4 John Siemens 2 September 22, 2008 14:39
Problem while running solver in star4.0 for linux deisler Siemens 7 March 14, 2007 04:16
Parallel processing in star3.24 Antony Siemens 4 July 19, 2005 00:45
star3.22 multi cpu carno Siemens 3 January 14, 2005 07:04
convert of file from star3.05 to star3.1 Rachid Siemens 2 March 3, 2000 10:11
