-   CD-adapco (http://www.cfd-online.com/Forums/cd-adapco/)
-   -   How to import grid generated using ICEM/CFD (http://www.cfd-online.com/Forums/cd-adapco/55304-how-import-grid-generated-using-icem-cfd.html)
Harry April 16, 2006 06:35
the version of my star-cd is 3.24. ICEM/CFD is 10.0 I generate a 2d grid using icem/cfd, and get three files (*.cel,*inp, *.vrt). After starting pro-star, I try to import the grids from "create and import grids/import grids" in guide of star-cd. I choose "format" as "Pro-star" or "ICEM", and get the almost same meassage in output window as follows, vread,kuang.vrt,0, , ,coded READ VERTICES FROM FILE kuang.vrt USING OFFSET = 0 STORE VERTICES 1 THROUGH 999999999
2048 VERTICES READ IN FROM FILE kuang.vrt MAXIMUM VERTEX NUMBER IS NOW 2048
2048 IS MAXIMUM VERTEX NUMBER IN FILE
MESH*> cread,kuang.cel,0, , , modify,coded, 0, READ CELLS FROM FILE kuang.cel OFFSETTING VERTICES BY 0 STORE CELLS 1 THROUGH 999999999 AND USE EXISTING CELL NUMBERS OFFSET FOR CELL NUMBERS = 0 OFFSET FOR CELL TYPE NUMBERS = 0 **WARNING - CELL 1 HAS A NONEXISTENT CELL TABLE NO. ( 7)
IT WILL BE DEFINED
1901 CELLS READ IN FROM FILE kuang.cel MAXIMUM CELL NUMBER IS NOW 1901
The problem is that When I want to check/display the imported grids in pro-star, an erro tells me that there is no any available grids. What do I miss? Or How should I do? I would appreciate your help. Harry
Harry April 16, 2006 06:38
Re: How to import grid generated using ICEM/CFD
IT WILL BE DEFINED
Regards,
Harry
harry April 17, 2006 00:01
I have solved it myself. the problem comes from my carelessness
