Pro surf
Old   April 20, 2006, 07:25
Default Pro surf
Konstantinos
Hi, im trying to use pro surf to generate a grid, but I get way more cells than what I want, what values should I change so that when i regenerate the grid I get less cells?
Thanks
Old   April 20, 2006, 08:37
Default Re: Pro surf
a student
HI,
Try to increase the max length when you perform surface triangulation. By the way what is the way of volume mesh generation?
I hope this will do.
Old   April 20, 2006, 08:50
Konstantinos
What maximum length though? In the generate surface grid option there are 4 lengths. The maximum curve lenght , the minimum curve legth (both of these are reference lengths) and the triangle length scale and the minimum length scale due to curvature.... The triagnle length scale is 0.0021517 and the minimum length scale is 0.00199027.... What do you thing would be suitable values?
I dont know what is the way of volume mesh generation, i am not very familiar with pro surf....
Thanks for your help!
Old   April 20, 2006, 09:31
Konstantinos
Hi again,
I managed to change the max lengths so that the triangulation complete. Now though, i want to import it to prostar, but i dont know if i should save it as iges or as dbs. Because in the user guide it seems like dbs is what i need, but i cant find a way to input a dbs file in prostar... Any ideas?
Old   April 20, 2006, 09:38
Ralphie
You have to use proam to open a *dbs file.
Old   April 20, 2006, 10:11
Konstantinos
Thanks, i managed to do that too, and i can open the file but when i start generating the mesh, at step 3 where i generate the subsurface, i get segmentation fault... And also in step 2 i get a message saying that I have 25 non manifold points. Can these two errors be connected? If yes how can i fix it?
Thank you for beeing so helpfull!
Old   April 20, 2006, 11:49
a student
Increase your max triangle length scale and see how your surface triangular density decreases.
And first try to resolve manifold error with the help of available literature(user guide),then go further.
Wish you good luck.
Old   April 20, 2006, 13:11
William Blake
It is probably a good idea to read some manuals and run the tutorials.
Old   April 21, 2006, 04:36
Alex
I have had the same problem, and i looked through the user guides and tutorials and i did not find anything around the topic...
Old   April 21, 2006, 12:11
William Blake
proam_uguide.pdf chapter4 : surface preparation
Old   April 21, 2006, 13:18
  #11
Alex
Oh thanks! Lol, i understand how to do the surface checks but i cant fix the problems it finds (6634 failed out of 103983 , shit, is that too much?!!!!) , my english is not this good sorry, and i get confused by the manual
still, thanks
Old   May 10, 2006, 08:32
  #12
usker
Is your way of generating mesh: solid model-> pro-Star/surf -> Pro-Star/amm -> mesh generation? If so then the fault you get is probably because of the way you generated your solid model.
Regards
Importing Unigraphics model in to Pro-surf Sundar.M Siemens 2 June 26, 2006 09:30
Simple query on Pro Surf Venkatesh.V Siemens 0 April 22, 2006 02:32
surf wrap - baffle thickness azmir Siemens 0 April 20, 2006 09:59
What are trimming loops in pro-surf? Alicia Siemens 1 September 1, 2005 15:55
Catia V5 and Pro-Surf Rainer Siemens 4 June 18, 2004 03:58
