Convergence in a conjugate heat transfer problem
Old   June 2, 2006, 08:40
Default Convergence in a conjugate heat transfer problem
dp
Hello guys,
I am solving a conjugate heat transfer flow problem with heat generation. I am getting good convergence of Fluid parameters WITH little tunig of underrelaxation parameters.But for solid MATERIAL enthalpy residuals are not converging. HOW TO GO FOR IT.also how to set convergence criteria for solid seperately. Thanks in advance.
Old   June 5, 2006, 03:53
Default Re: Convergence in a conjugate heat transfer probl
DenizeN
Try duble precision.
Old   June 5, 2006, 10:08
katghir
use PISO algorithm. using steady state sol not converged means try to use transient (Pseudo transient).
Old   June 6, 2006, 00:11
dp
Thanks a lot. let me try.
Old   June 6, 2006, 06:40
Stephen
The problem is that the thermal response times of your solid and fluid are probably very different.
If your problem is not bouyancy dependedent, you could try switching of the enthalpy solver and solving just the flow field - once this has converged, do the opposite, switch off solution of everything apart from enthalpy and continue the calculation.
Old   June 8, 2006, 10:31
moritz
I had the same problem, and I get the best convergence with a "solid cell temperature under-relaxation factor" of 0.999 ("thermal options" panel or conj,on,0.999), with 1 it doesn't converge and with 0.9 very slowly. Please let me know if this helps. In the StarCD user guide it is recommended to leave just one under-relaxation factor below 1. So try to set the fluid under-relaxation factor to 1.
Old   June 9, 2006, 00:53
dp
Thanks for the suggestions.Let me try and see. I will let u know whether it works.
Conjugate heat transfer problem in 3D Tanveer FLUENT 1 June 17, 2008 02:15
Conjugate heat transfer problem Soheyl FLUENT 2 March 15, 2008 14:15
Convergence problem in conjugate heat transfer Scibor Siemens 2 June 18, 2007 16:08
conjugate heat transfer problem Andreas CFX 1 February 5, 2002 18:22
conjugate heat transfer problem Andreas Siemens 0 February 5, 2002 08:00
