Home > Forums > CD-adapco
MRF-explicit-Pressure & Inlet coupling
Old   May 1, 2006, 05:09
Default MRF-explicit-Pressure & Inlet coupling
sham
Hello erverybody, I have a question regarding Torque converter analysis. I have taken one sector from each of 3 components (Impeller, reactor &turbine). I have applied Inlet & Pressure boundary conditions at each component ends. And coupled these boundaries by regions.And grouped into 1 & 2. I tried to solve with explicit Multiple frames. For some reason the coupling between inlet and pressure boundaries is not happened. I think some problem with coupling of boundaries and grouping the couples. It would be great, if someone could help me with this matter.
Old   May 1, 2006, 12:19
Default Re: MRF-explicit-Pressure & Inlet coupling
Vanessa Phelps
Have you read the manual? do you use group 0, there are restriction if you use group 0. Are the 3 component 3 different materials? it must be 3 materials; for this type of coupling starccm+ is more convnient anyway. You'd rather use starccm+
Old   May 2, 2006, 05:09
sham
Thank you vanessa. Yes 3 domains are in 3 different materials. I am using Groups.
Thread Tools
Trackbacks are On
Explicit Solver and pressure correction hjasak OpenFOAM Running, Solving & CFD 1 October 5, 2006 07:16
Multiple frames-Coupling Pressure & Inlet problem sham CD-adapco 1 June 9, 2006 00:39
Velocity-Pressure coupling Diego Nogueira Main CFD Forum 3 July 18, 2004 13:39
Explicit Pressure Based Scheme Apurva Main CFD Forum 4 June 3, 2004 20:01
pressure coupling Faruk Selimovic FLUENT 4 May 1, 2003 12:18
