Help!! Empty post register
Hello, i tried different commands, somehow the register value remains blank. Case: transient. Fluid cells are projected on shells and sensor vertices are also present. Want: to export the SU,SY,SW,VMAG and P for particular shell-cells and sensor vertices as table. TRIED: stor,xxx cset news flui mapped them on shells cset news shell oper,getc,p,4 OR vset news shell oper,getv,p,4 the REGISTER REMAINS BLANK.
Thanks, |
Re: Help!! Empty post register
If you are really doing things in the order you say, I don't think it should work. You should
trload STOR, OPER, GETC,P 4 (print all just to make sure you got data) Then map the data to shells. Then it should be there. If you oper getc p 4 last after you map, you wipe out the results of any mapping. |
Hello, thanks but i have the case that i want data at particular sites, specifically for this i mapped the fluid cells on particular planes (created at sensor vertices locations). WHat i want is following ( I find STAR-CD horrible regarding post-processing): I have a loop STOR ... for the fluid cells i now do getc,none,p caver,cset now i map on particular planes (created at sensor locations) CSET NEWS CLIS oper,getv,.. ... with GPAR i get the data in graph register What i want is: export 'POST' DATA for these few shell-cells at sensor locations. At the moment the POST-REGISTERS remain empty and GRAPH REGISTERS are filled through the MACRO i use.
How to fill the POST REGISTER and export ALL data (also from GRAPH registers) as table ? Thanks, |
Its horrible how in the message the line-feed is not taken into account, sorry (can I influence this as a user?)
You are mixing up too many things at once. If you map data to shells then you dump that data out of the POST registers for each shell. If you map data to sensor points and store that in the GRAPH register then that is something entirely different and unrelated. You dont need to map to shells in order to map to sensors. The easiest thing to do is use the Nav Center. Go to Graphs->Extract->Field Data Use the panel to create a few new sensor points, map and then store and create a graph. Then use the External Data panel to write it out. All the commands that these panels use will be written to the echo file. You should be able to understand how to adapt them to use your sensor original points instead.
Thanks, i will try this out.
Hello, I tried also at the NAVCENTER-> GRAPH and so on but am not able to get the data I want. The script I use is: (aim to get data in graph registers, actually for export) I have not written the MAPPING on shells part.
oper,clear,all rclear, all gres y *set DRUCK 0 0 batch on *set INCREMENT 0 1 trload,star**.pttc,mvgr on n *define noex store iter INCREMENT *get ZEIT time cset,news,clis,NR. vset,news,cset,all oper,getv,p,4 *get DRUCK,post,4, gpar,ZEIT,1,INCREMENT gpar,DRUCK,2,INCREMENT *end *loop 1 N 1 batch off When looking at GRAPH REGISTER, it sometimes just does not update data. What could the reason be ? Thanks. |
*set DRUCK 0 0
batch on *set INCREMENT 0 1 trload,star**.pttc,mvgr on there is no 'on' option. Its mvgr or nomvgr. I don't think a wild card is allowed either (not really sure -never used it). If you want to load multiple files, I think you need trload,star001.pttc,mvgr,N (where N is number of files to load). Then it asks you for file names. n *define noex store iter INCREMENT There is no 'ITER' option. Its 'ITSTEP'. *get ZEIT time cset,news,clis,NR. where does 'NR' come from? Is it defined? vset,news,cset,all oper,getv,p,4 *get DRUCK,post,4, You are missing the last field which is the data item to get It should be *GET DRUCK POST 4 N (where N is the vertex number) gpar,ZEIT,1,INCREMENT gpar,DRUCK,2,INCREMENT *end *loop 1 N 1 batch off |
Due to older version the commands were accepted !!! (I will check this out). With Nr i meant vertex or cell nr. which is entered. Thank you very much for your response, I am continuing the work.
