-   CD-adapco (http://www.cfd-online.com/Forums/cd-adapco/)
-   -   Meshing (http://www.cfd-online.com/Forums/cd-adapco/55345-meshing.html)
Jorge May 4, 2006 22:55
Meshing
Dear all, i am a begginer using starcd 3.22:
I want to mesh a truncated cone in star 3.22, how could i do it, the bottom ratio is 148.95 mm, upper ratio:124.4 mm, height:210 mm.
Thank you in advance for your help
rajesh May 5, 2006 02:21
Re: Meshing
hi,
examples are given in users manual...its rather easy just go through it you can use block meshing for your geometry...no need of automesh
Jorge May 6, 2006 00:50
Re: Meshing
Hi:
Sorry, i am beginning with Starcd, but, are there any example on the user manual about this geometry?, or what command could i use.
Thanks
liya January 19, 2011 21:05
Hi, I am a begginer at CFD, please help anyone with my mesh. I defined 2 radial edges in a laminar pipe (# of devisions 30) and 2 top and bottom edges of the same pipe (# of devisions 100). under mesh/statistics shows 3000 elements, where i should get 6120 by the stated problem. what did i miss? Also, i cannot plot XYplot, gives me error: no data points in range, what does it mean? thanks.
hwangkl January 19, 2011 22:47
Originally Posted by Jorge
;171337
echo off
csys,2
vc3d,0,148.95,10,0,360,36,0,210,1
vset, all
vmerg,vset,,0.0001,,,,,,,low,delete
c
cset,all
vset, news, edge
vset subs gran ,,,,,200
vmod vset 124.4 f f
vset add gran ,,,,,,200
vsmo 1 1000
crefine,1,1 ,10,cset,0,0,merg,nocouple
cset,all
cplo
