May 1, 2006, 04:28 |
CCM+ bad_alloc
Does anyone know anything about "bad_alloc" errors in starccm+?? Occurs when I try and run the model. What could be causing this? How do I prevent it?! Thanks
May 1, 2006, 10:54 |
Re: CCM+ bad_alloc
save your model after meshing. shutdown ccm+ and then restart it.
May 2, 2006, 11:38 |
Re: CCM+ bad_alloc
bad_alloc is the standard c++ out of memory error. It probably failed to allocate enough space for the solution data.
As TG wrote, if you just generated the mesh, re-starting may allow you to proceed. If not, you may need more memory or a smaller mesh (fewer cells). |
May 2, 2006, 16:30 |
Re: CCM+ bad_alloc
Now THAT sounds like something Micro$oft would offer you as a solution to bad code!
May 3, 2006, 11:33 |
Re: CCM+ bad_alloc
try changing to explicit! and change the Courant no to very small for the begining say 0.1
May 5, 2006, 10:18 |
Re: CCM+ bad_alloc
In fact this problem is worse on windows for various reasons. Try googling "heap fragmentation windows" ...
Display Modes | |
