-   CD-adapco (http://www.cfd-online.com/Forums/cd-adapco/)
-   -   In what condition need the tran.dat file (http://www.cfd-online.com/Forums/cd-adapco/55360-what-condition-need-tran-dat-file.html)
Fengwei May 10, 2006 05:05
I am working on c12h26 autoignition. when solving, the tran.dat is required. but when I copy the file into the working folder, it is told that SPECIES C12H26 CAN NOT BE FOUND IN tran.dat. so what can I do to make the solution need not the tran.dat file? Thanks a million.
chinayu May 10, 2006 09:17
Re: In what condition need the tran.dat file
tran.dat is used when chemkin module has been run, you should check the tran.dat file to confirm that c12h26 is inclued in the file.
sham May 11, 2006 07:04
what combustion model using?
chinayu May 15, 2006 10:44
none
