warning #057
Old   May 16, 2006, 11:29
Default warning #057
a student
Hello everybody,
I have warning #057, i.e equation of state imbalance at xyz cell in 2-stroke engine combustion run. There are around 40 cells displaying this warning and I found them located near by exhaust port boundary (pr.) and very few near by inlet boundary.
Should I ignore this warning which is only absent in the middle portion of the run. And I have high HDIFF value also. Please advice.
Thanking you.
Old   May 16, 2006, 16:21
Default Re: warning #057
GU
the equation of state is not converged in those cell, what actions can you take to help the solver converge?
Old   May 16, 2006, 17:18
a student
Hello GU,
I know I can not help solver but I am curious to know why at those locations only.
Old   May 17, 2006, 06:42
John
Take a look at the values of these imbalance. Normally there are very small and can be ignored with certainty.
Old   May 18, 2006, 01:44
a student
Hello John,
Yes as you mentioned they are very small. Thank you much for your reply.
Do you know why my model crashes near the closing of ports due to -ve density.
Thanks alot.
Warning 046, what does it mean? SAKTI Siemens 1 July 31, 2008 12:14
warning #064 ema Siemens 1 August 25, 2005 05:45
warning # 90 vishal Siemens 1 August 11, 2005 09:19
*** WARNING #052 *** Cirilo Siemens 1 July 27, 2005 08:34
Warning Paco Siemens 0 June 23, 2005 02:33
