Home > Forums > CD-adapco
Linex OS bloks memory
Old   May 23, 2006, 23:20
Default Linex OS bloks memory
css
Hi friends,
I am meshing (using pro*am)a huge problem (around 9 million cells) in cluster M/C with the following configuration,
OS - Linux (scientific Linux)
CPU's - 2
RAM capacity - 6 GB's each (12 GB's total)
I have encounted the following,
When I started the meshing work (after restarting the m/c) it initially took 2 GB's of memory and at the end of day 11 GB's get's blocked even after closing all activities i.e. I came out from all the activities still it shows 11.3 GB's in use.
Pl. give me a suggestion to sort-out this problem.
Thanks in advance C.Shanmugasundaram
Old   May 27, 2006, 16:59
Default Re: Linex OS bloks memory
TG
The first question is which Linux are you using and second is are you sure you installed the 64bit linux version of STAR?
Old   May 29, 2006, 06:16
css
Dear TG,
Thanks for your replay and details are,
Linux - using both Fedora and scientific Linux
STAR-CD Version- 3.22 (32 bit version of star)
Thanks and Regards C.Shanmugasundaram
Old   May 29, 2006, 08:12
TG
I'm afraid you have 2 problems.
1) Fedora isn't supported and I don't know what you mean by scientific Linux
2)You can't take advantage of more than 2 (or maybe 4)Gb of memory with a 32bit version. You need a 64bit OS and the 64bit version of STAR to take advantage of all your memory.
Old   May 29, 2006, 08:26
css
Scientific linux also a 64 bit version of linux only. As you told i will try 64 bit version of star-cd (3.24 or 3.26)and get back to you.
Old   July 26, 2006, 06:27
css@csmsoftware.com
Dear TG,
I have tried star-cd 64 bit version in 64 bit scientific linex. Stil facing the same problem. Can any one help me out.Thanks in advance.
Regards C.shan
Old   November 7, 2006, 04:14
KRISHAN
SIR PLS YOU ARE SED ME MASSEGOF LINEX OS
Old   November 7, 2006, 14:09
Ben
what on earth are talking about?
Thread Tools
Trackbacks are On
Out of Memory Naghman Khan FLUENT 3 August 30, 2007 06:08
Memory 400-667 MHz George Main CFD Forum 8 March 1, 2007 09:22
Not enough memory... DAK565656 CFX 1 September 17, 2005 13:36
Memory is too low Aireen FLUENT 3 September 7, 2005 10:25
Memory Christian Cordeiro CFX 9 June 11, 2003 08:12
