May 24, 2006, 13:53 |
Sensor- problem
I made 205 vetices using the vert command. I want to use them as sensors for extracting temperatures. I tried the sensor command, however, the sensors x y z are different than the vertices. How I can use only the vertices as sensors? . Thanks in advance. W.A.
May 26, 2006, 15:47 |
Re: Sensor- problem
sounds like you all ready have sensors defined. try deleting them & re-creating.
sens dele all build a vset of your 205 vertices sens add vset sens scan all |
May 29, 2006, 21:32 |
Re: Sensor- problem
Thank you very much Mr Pauli, it works well. My best regards. W.A.
June 1, 2006, 09:27 |
Re: Sensor- problem
i want to create sensor in a single line, tell me the procedure,,
thanks |
June 1, 2006, 10:53 |
Re: Sensor- problem
if the vertices don't exist, gpost with the points option
or if they do exist, build a vertex set then sens add vset$sens scan I like gpost because it puts the results in a graph register which is convenient for plotting results. |
Sensor problem with star-CD | Yongli Qi | Siemens | 2 | June 30, 2008 11:38 |
OFILE SENSOR | guest7777 | Siemens | 0 | April 20, 2006 05:12 |
Sensor points | Aline | Siemens | 2 | August 16, 2004 09:52 |
A problem about the sensor points | Lee | Siemens | 3 | October 31, 2003 13:32 |
a better sensor | achim | Siemens | 1 | January 19, 2001 15:39 |
