May 27, 2006, 04:00 |
polyhedral mesh
I am confused by polyhedral cell. I have read the article by Peric. It makes a good sense. However does it take a feature of geometry, similar dimension. If not, what is the point.
May 27, 2006, 09:32 |
Re: polyhedral mesh
Polyhedral cells are basically a step up from tetrahedrals in that their generation is automatic and is grown from a surface triangulation, the point of them is that they are easier to generate than hex/trim meshes but have nearly comparible accuracy, are faster to converge, more accurate and less numerically diffusive than tetras
May 27, 2006, 21:55 |
Re: polyhedral mesh
Thank you Ben. But I guess those cells in between polyhedral cells would be smaller in size so that would finally break the rule: change in cell size < 1.2?
May 28, 2006, 02:02 |
Re: polyhedral mesh
There are generally no cells between polyhedral cells. In 99.9% of all cases, polyhedras are connected to other polyhedras.
Display Modes | |
Polyhedral Mesh | Diego Flores | FLUENT | 17 | August 21, 2020 14:52 |
[Technical] Polyhedral mesh generation | lr103476 | OpenFOAM Meshing & Mesh Conversion | 49 | July 17, 2012 03:59 |
SampleSurface with polyhedral mesh | braennstroem | OpenFOAM Post-Processing | 1 | February 29, 2008 05:30 |
Polyhedral mesh in Fluent | Shri | FLUENT | 3 | August 22, 2007 05:31 |
polyhedral mesh generator? | phsieh2005 | Main CFD Forum | 2 | January 17, 2007 20:54 |
