blocks
Old   June 5, 2006, 07:01
Default blocks
sogunuru
1.can we specify solid and fluid cells within a single block? 2.once the cells are deleted in a block,how to delete corresponding vertices? 3.how to create a triangular block?
Old   June 5, 2006, 19:10
Default Re: blocks
student
A2- gethear rest of the cells in a set and do vset newset cset after that do vset invert which should give you vertices of deleted cells.
[mesh manipulation] Stitch meshes with more two blocks vantage1 OpenFOAM Meshing & Mesh Conversion 4 March 12, 2010 08:04
[blockMesh] Grouping blocks ehsan_vaghefi OpenFOAM Meshing & Mesh Conversion 0 September 1, 2008 23:32
common blocks CMB Siemens 1 November 12, 2004 10:41
Flows over blocks A.Sakin FLUENT 0 September 10, 2003 10:27
Connecting blocks with multi-blocks methods Sebastien Perron Main CFD Forum 3 March 7, 2001 17:55
