June 5, 2006, 06:01 |
blocks
1.can we specify solid and fluid cells within a single block? 2.once the cells are deleted in a block,how to delete corresponding vertices? 3.how to create a triangular block?
June 5, 2006, 18:10 |
Re: blocks
A2- gethear rest of the cells in a set and do vset newset cset after that do vset invert which should give you vertices of deleted cells.
[mesh manipulation] Stitch meshes with more two blocks | vantage1 | OpenFOAM Meshing & Mesh Conversion | 4 | March 12, 2010 07:04 |
[blockMesh] Grouping blocks | ehsan_vaghefi | OpenFOAM Meshing & Mesh Conversion | 0 | September 1, 2008 22:32 |
common blocks | CMB | Siemens | 1 | November 12, 2004 09:41 |
Flows over blocks | A.Sakin | FLUENT | 0 | September 10, 2003 09:27 |
Connecting blocks with multi-blocks methods | Sebastien Perron | Main CFD Forum | 3 | March 7, 2001 16:55 |
