June 7, 2006, 09:50 |
How to model intersecting pipes
Hi, I am modelling two intersecting pipes(normal to each other) in Star CD. But, the problem is how to get the curve of intersection of the two pipes...pleace respond as early as possible. Thanks in advance Ankush Aggarwal
June 8, 2006, 09:35 |
Re: How to model intersecting pipes
Try VINTERSECT command. You need one pipe to be represented by fluid cells and the other by surface shells for it
June 8, 2006, 10:33 |
I have made the interface using vproject and completed the meshing but there are some overlaping cells at the intersection of the pipes(even though I projected the vertices on the surface)....and I don't know how to correct that....if you can help please. Thanks
Display Modes | |
intersecting cylinders | m malik | Main CFD Forum | 2 | November 2, 2011 09:25 |
model of pipes inside pipe | carmen | FLUENT | 0 | January 22, 2009 10:27 |
Intersecting sliding interface | jaswi | OpenFOAM Running, Solving & CFD | 0 | February 15, 2008 01:07 |
self intersecting (mesh volume) | Eko | CFX | 0 | May 30, 2007 19:55 |
Self intersecting | Carlos Saraiva | Siemens | 0 | January 23, 2003 09:33 |
