Including baffles in automatic meshing(pro amm) |
June 27, 2006, 09:45 |
hi, i m using pro amm to mesh a steam transmission pipe with some baffles inside it(because of which i can't mesh it in pro star)......the baffles are floating...i mention the baffle shells during the subsurface creation (as given in the manual) ....but in the end there are no baffle cells created.... when to make the baffles etc.... if any one knows solution to this please help me out.... thanks in advance
June 27, 2006, 16:49 |
Re: Including baffles in automatic meshing(pro amm
what sort of mesh are you generating? If the subsurface and extrusion layer generate correctly you should see disconected vertices in the final mesh where the two extrusions meet, i.e. where the baffles are, you can then just cfind or live surf it. If you are generating a tetra mesh then just use the original surface.
June 28, 2006, 03:24 |
i am generating tetrahedral mesh....
yes after meshing....it is disconnected at the surface defines as baffle(which i noticed later)....how to use cfind or live surf command to generate shell surface there..... and for using the original surface in tetra mesh....there is no surface anymore after the assembly..... however it says....disconnected vertices will act as impermiable adiabatic baffles..... |
Display Modes | |
Including Gravity Component | Robert | FLUENT | 1 | November 30, 2008 17:05 |
Including a new utility in OF 13 | alondono | OpenFOAM Running, Solving & CFD | 7 | April 11, 2008 10:17 |
[Salome] OpenFOam Automatic Meshing | bastil | OpenFOAM Meshing & Mesh Conversion | 2 | August 9, 2007 17:06 |
automatic meshing problem | jemteo | FLUENT | 1 | November 21, 2005 00:37 |
including gravity in 1D model | Amir Filipovic | Main CFD Forum | 0 | November 18, 2003 16:23 |
