Please help
Old   June 28, 2006, 05:30
Default Please help
Mertiny
the problem specification is-
there is a cubical cavity with two isothermal faces and the remaining four sides having a linear temperature distribution. the cavity is heating from below. my problem is - how to apply the linear temperature distribution boundary conditions for the four side walls?
pls help me. i will be very much grateful.
Old   June 28, 2006, 06:33
Default Re: Please help
Ben
use a table or some user code
Old   June 28, 2006, 07:18
William Blake
The flow inside the cavity usually changes the linear profile. So it is better to model the heat conduction together with the fluid flow --> conjugate heat transfer.
Old   July 1, 2006, 01:20
shanta
Thanks Ben and Blake for ur help
