Please help
the problem specification is-
there is a cubical cavity with two isothermal faces and the remaining four sides having a linear temperature distribution. the cavity is heating from below. my problem is - how to apply the linear temperature distribution boundary conditions for the four side walls? pls help me. i will be very much grateful. |
Re: Please help
use a table or some user code
Re: Please help
The flow inside the cavity usually changes the linear profile. So it is better to model the heat conduction together with the fluid flow --> conjugate heat transfer.
Re: Please help
Thanks Ben and Blake for ur help
