Home > Forums > CD-adapco
star-CD V 3.26 - GUI display problem.
Old   July 13, 2006, 04:59
Default star-CD V 3.26 - GUI display problem.
Dr C.Bhasker
I have loaded star-CD V 3.26 Windows 2000 OS. Through MKS tools X windows are activated through Hammingbird EXCEED. Solver - Star works. When prostar is launched after selecting OPENGL in the file under preferences, it just hangs with the command prostar glm. As a result I am unable to see the GUI display of pre-processor. If any body has this experience, kindly provide the hint. if it is bug, software vendors may kindly suggest some remedy.
Dr C.Bhasker
Old   July 13, 2006, 18:27
Default Re: star-CD V 3.26 - GUI display problem.
TG
Its likely that Hummingbird is not set to open automatically when sensing X activity. Try opening it before you start up prostar. You also might be having firewall problems. Try turning all your firewalls off just temporarily.
Old   July 13, 2006, 23:28
Pialisen
I too had the same problem. I had installed star cd V3.26 and Exceed V 11.0. I had not installed MKS toolkit.
Though i try by first opening Exceed X window and then pro-star. Prostar GUI is not opening
Is it possible to open pro-star with out installing MKS toolkit.
Any help in this regards please
Old   July 14, 2006, 00:39
Dr C.Bhasker
MKS tool is one where we activating x windows. I think this has to be loaded. Previous versions 3.24, 3.15A works fine. Some problems with star-cd v.26 connection with opengl problems. May be a chance can be taken under windows XP operating system.
Bskr
Old   July 14, 2006, 11:23
TG
It is not possible to run prostar without installing MKS. If you have never installed it before you need to get the MKS toolkit directly from CD-adapco.
Old   July 14, 2006, 23:25
Pialisen
Thank you for your information
Old   July 15, 2006, 01:07
Dr C.Bhasker
earlier I have requested to know the location of firewall folder under windows 2000 operating system. I am unable to this under control panel. Once I about this, probably I will figurout the star-cd display problem.
bskr
Old   July 16, 2006, 11:45
TG
I don't think windows included a firewall with win2000. I also don't know for sure if the latest version of 3.26 officially even supports win2k anymore.
Old   July 16, 2006, 22:20
Dr C.Bhasker
I have tried by installing the star-cd v 3.26 under windows xp. I have also not loaded exceed nor activated x windows through MKS tool. To my surprise, star-design, design-post which are highly graphics oriented works fine. Even star solver works fine. Pro-star hangs without giving any error. But it looks all module works fine under linux operating system. May be I will try after some time.
bskr
Old   July 17, 2006, 07:27
TG
star-design and design-post were written long after prostar and use graphics that don't require an X server. star is a batch process and doesn't do any graphics so of course it doesn't need an X server. Prostar is migrating towards that same goal but its still mks/X based. That's why prostar still needs MKS and an Xserver and won't work without one.
Thread Tools
Trackbacks are On
ParaView display problem holzmichel OpenFOAM Bugs 7 April 27, 2009 18:42
problem with display john FLUENT 8 March 14, 2009 12:40
3D display problem Victor Cano FLUENT 1 December 18, 2008 20:35
DPM uncoupled display problem K. Jagus FLUENT 0 July 7, 2005 03:06
Pro-Star X display Mora CD-adapco 3 June 20, 2005 06:00
