July 13, 2006, 05:59 |
star-CD V 3.26 - GUI display problem.
I have loaded star-CD V 3.26 Windows 2000 OS. Through MKS tools X windows are activated through Hammingbird EXCEED. Solver - Star works. When prostar is launched after selecting OPENGL in the file under preferences, it just hangs with the command prostar glm. As a result I am unable to see the GUI display of pre-processor. If any body has this experience, kindly provide the hint. if it is bug, software vendors may kindly suggest some remedy.
Dr C.Bhasker |
July 13, 2006, 19:27 |
Re: star-CD V 3.26 - GUI display problem.
Its likely that Hummingbird is not set to open automatically when sensing X activity. Try opening it before you start up prostar. You also might be having firewall problems. Try turning all your firewalls off just temporarily.
July 14, 2006, 00:28 |
I too had the same problem. I had installed star cd V3.26 and Exceed V 11.0. I had not installed MKS toolkit.
Though i try by first opening Exceed X window and then pro-star. Prostar GUI is not opening Is it possible to open pro-star with out installing MKS toolkit. Any help in this regards please |
July 14, 2006, 01:39 |
MKS tool is one where we activating x windows. I think this has to be loaded. Previous versions 3.24, 3.15A works fine. Some problems with star-cd v.26 connection with opengl problems. May be a chance can be taken under windows XP operating system.
Bskr |
July 14, 2006, 12:23 |
It is not possible to run prostar without installing MKS. If you have never installed it before you need to get the MKS toolkit directly from CD-adapco.
July 15, 2006, 00:25 |
Thank you for your information
July 15, 2006, 02:07 |
earlier I have requested to know the location of firewall folder under windows 2000 operating system. I am unable to this under control panel. Once I about this, probably I will figurout the star-cd display problem.
bskr |
July 16, 2006, 12:45 |
I don't think windows included a firewall with win2000. I also don't know for sure if the latest version of 3.26 officially even supports win2k anymore.
July 16, 2006, 23:20 |
#9 |
I have tried by installing the star-cd v 3.26 under windows xp. I have also not loaded exceed nor activated x windows through MKS tool. To my surprise, star-design, design-post which are highly graphics oriented works fine. Even star solver works fine. Pro-star hangs without giving any error. But it looks all module works fine under linux operating system. May be I will try after some time.
bskr |
July 17, 2006, 08:27 |
#10 |
star-design and design-post were written long after prostar and use graphics that don't require an X server. star is a batch process and doesn't do any graphics so of course it doesn't need an X server. Prostar is migrating towards that same goal but its still mks/X based. That's why prostar still needs MKS and an Xserver and won't work without one.
Display Modes | |
ParaView display problem | holzmichel | OpenFOAM Bugs | 7 | April 27, 2009 19:42 |
problem with display | john | FLUENT | 8 | March 14, 2009 12:40 |
3D display problem | Victor Cano | FLUENT | 1 | December 18, 2008 20:35 |
DPM uncoupled display problem | K. Jagus | FLUENT | 0 | July 7, 2005 04:06 |
Pro-Star X display | Mora | Siemens | 3 | June 20, 2005 07:00 |
