PROSTAR
Old   July 25, 2006, 13:17
Default PROSTAR
Emmanuel Resch
I know this may sound ridiculous, but how do you undo a command in prostar!?
Old   July 25, 2006, 15:21
Default Re: PROSTAR
Pauli
quit,nosave prostar glm
i.e. no undo button
Old   July 25, 2006, 16:25
Default Re: PROSTAR
Yes
save the model before the command you are unsure of, then resume...
save,, resume,,
Old   July 25, 2006, 19:03
Default Re: PROSTAR
Kevin
Come now Pauli and Yes....
In prostar, there is the recover command. If you make a mistake, simply type recover,,
It will give you a list of all command that you have done since you lasted saved the model. You simply enter in the number prior to where you made the mistake, and prostar will simply follow all of your steps in exact repeat, up until the point that you specify. This has been in the code for atleast 10 years.
Old   July 26, 2006, 08:21
Default Re: PROSTAR
Emmanuel Resch
i knew there had to be some common sense written into that software somewhere... thanks Kevin
Old   July 26, 2006, 14:24
Default Re: PROSTAR
Warning
recover commad does not work for all commands, sometimes you need to use VUNDO.
Old   July 27, 2006, 15:08
Default Re: PROSTAR
Pauli
Sorry, I forgot about that one because I never use it. I resume & then cut & paste from the echo file. I prefer the control - I can leave out all the steps I don't really need.
Old   August 1, 2006, 08:37
Default Re: PROSTAR
moritz
There is also CUNDELETE to recreate deleted cells, since the last CCOMPRESS operation.
It is difficult to use recover, if you used your courser (e.g. to selcect cells, faces etc.)
If I create a mesh by hand or I have to set up a large amount of boundary conditions I always use a macro. That is the easiest way to repeat every operation.
Prostar "cutie" ? field function Siemens 0 December 2, 2007 14:43
Prostar doesn't starts Ruggero Siemens 2 July 8, 2007 16:53
prostar Error Pialisen Siemens 2 September 9, 2006 14:06
prostar/buttons Michiel Siemens 8 July 15, 2004 09:01
where can i buy Prostar starCD Abdi Main CFD Forum 1 October 22, 2002 18:00
