May 14, 2006, 22:49 |
error#86and#106
I generated the mesh automatically with es-ice.But when I finished all the set up within Prostar according to the tutorial example and tried to write a geometry file,fowllowing errors appeared:
error#86:master and slave cell faces of couple donot overlap error#106:faces of couple are not close enough to to be valid These are the messages displayed when writing geometry file only. There are other errors if grid checking was done(it is said that there is no need for grid checking using es-ice). Has anyone ever met this problem? I am wondering how to fix them. The linux I use is fc5.Dose it have anything to do with the system? |
May 15, 2006, 05:37 |
Re: error#86and#106
Do a couple check and take all the faulty couples in one set and then delete them. If you want to be on the save side, do a crack check afterwards. Alternatively, get V4. There is no need for couples in the new version.
May 16, 2006, 16:15 |
Re: error#86and#106
There is no es-ice or moving though
May 17, 2006, 04:26 |
Re: error#86and#106
Hmm, good point...
May 17, 2006, 23:52 |
Re: error#86and#106
Thanks! I chose "Remove non-overlapping slaves"in the couple check,and right now there seems to be no couple problems.
But a new error occurred when I wrote the geometry file this time. Eerror#270:Event data file is not connected. What does this mean? |
July 26, 2006, 07:25 |
Re: error#86and#106
connect the event file by issuing command 'evfile conn'.It will connect the event file which you written already.
shan |
strange fluent error: Primitive Error at Node 0 | Jean-Baptiste | FLUENT | 8 | June 14, 2022 11:11 |
error in COMSOL:'ERROR:6164 Duplicate Variable' | bhushas | COMSOL | 1 | May 30, 2008 04:35 |
Fatal error error writing to tmp No space left on device | maka | OpenFOAM Installation | 2 | April 3, 2006 08:48 |
Error: Floating point error: invalid number | Bob | FLUENT | 3 | June 3, 2005 18:11 |
Gambit 2.0 - Error Message (ACIS ERROR 1200) | James | FLUENT | 1 | May 14, 2003 08:13 |
