Density Relation for Hydrogen Mixing
Old   August 3, 2006, 11:48
Default Density Relation for Hydrogen Mixing
Shariff
Dear All, I am modelling hydrogen leak in enclosed spaces, hence there is mixing of the gas(H2) with air at the exit of the leak. The speed of the gas at the exit is 20m/s at 4bar pressure, 15degC. The question is considering the non-ideal and compressible nature of the gas leaking at such low speed, and the constant density of air, what is the appropriate density relation to use when defining the molecular properties of air? Is it constant density, multicomponent mix, Ideal f(T) or Ideal f(T,P)? Furthermore, if I'm using a trimcell mesh with about 500,000 cell prepared in pro-amm, is there any good setting for the URF and residual tolerances? I have been getting divergence since I refined the mesh. Please I need guide from some with experience in similar model. Thanks
Implicit density pressure relation caw OpenFOAM Running, Solving & CFD 1 April 24, 2008 00:30
hydrogen combustion A.Subramani Siemens 1 December 1, 2007 20:05
Mixing = density change Paul Main CFD Forum 0 March 1, 2005 08:48
ideal gas mixing law and mass-weighted mixing law Shankar FLUENT 0 June 24, 2003 14:25
hydrogen/air mixing Marie Siemens 1 October 10, 2001 10:33
