Home > Forums > CD-adapco
error#014:negative volume(during calculation)
Old   August 25, 2006, 01:47
Default error#014:negative volume(during calculation)
lizhihua
Hi, I am doing engine intake and exhaust simulation with the example grids of es-ice,varying the valve lift curves.A former simulation has succeeded,however,when I employed a new set of valve lifts,error #014 appeared in the simulation(crank angle 617.4):
*** ERROR #014 *** NEGATIVE VOLUME CALCULATED FOR CELL NO.26618 (a cell right under the intake valve) IT IS PROBABLY LEFT-HANDED
No errors have ever been discovered during the "check negative volume" in es-ice,and no left-handed cells found in prostar.
Does anybody know why and how can I solve the problem? Thanks!
Old   August 27, 2006, 23:08
Default Re: error#014:negative volume(during calculation)
staruser
when you do the checking in es-ice, what is your crank angle?Is it 617.4CA ?
I think you have to identify the problematic cell during 617.4CA , then fix it by using es-ice manually. Thats what i'm doing normally.
Other forummers may have good idea on this.
Old   August 28, 2006, 00:10
lizhihua
Thanks first!
Yes,I checked the mesh at 617.4CA.Also I did the mesh checking from 615CA to 620CA.Neither case had a negative volume report.
When I tried "rcon 4 1" in star from 435CA(when intake valve opens) to 720CA, the error message appeared.But when it is running from 615 to 620 no problems were discovered! So I am really puzzled.
Thread Tools
Trackbacks are On
FSI Negative Element Volume Fatal Error Aaron CFX 2 July 1, 2008 20:48
Negative Volume Error Srinivethan CFX 3 December 11, 2007 17:27
negative solid volume error Luis CFX 3 October 30, 2007 19:04
solve negative volume error sravan Main CFD Forum 1 September 26, 2007 21:57
negative volume 2d AJG FLUENT 4 April 21, 2006 06:52
