creating spline along existing line cell?
Old   September 1, 2006, 00:44
Default creating spline along existing line cell?
guang ai
Hello everybody: I want creating a spline along exisiting line cell to catch up. However the command 'splc' only operating interactinvely on screen. There is no other command wayaround. I plan to run a loop to chase up a line. What I doing this is because 'splin chase' functioning very badly, could not go along slightly charpen curves.
Old   September 1, 2006, 08:23
Default Re: creating spline along existing line cell?
allan
I don't think you can do this, I asked the same question about two years ago at cd-adapco support, and I was told it couldn't be done. However things may have changed!
Old   September 1, 2006, 09:06
Default Thank you! *NM*
guang ai
Old   September 4, 2006, 02:33
Default Re: Thank you!
DenizeN
It is done simple.
The use of a negative vertex number in the vertex definition list provides for slope discontinuity at the location of the (absolute value) of the vertex. Use it to build you slightly charpen curves.
Creating a new case from command line gregh OpenFOAM Pre-Processing 25 November 14, 2013 07:38
Creating A Constant Pitch Helical Line In Gridgen John Hinkey Pointwise & Gridgen 2 August 5, 2007 00:01
matrxi line cell guang ai Siemens 0 April 14, 2005 00:59
Creating line/lake in dynamic mesh J.W.Ryu FLUENT 0 June 21, 2002 04:07
creating line for dispalying data ? siswara dana FLUENT 6 September 3, 2001 04:41
