Home > Forums > CD-adapco
prostar Error
Old   September 4, 2006, 00:06
Default prostar Error
Pialisen
Hai friends
I newely installed star cd 3.26 with Humming bird exceed and MKS. When i try to open prostar from STAR Launch, itis not opening. When i try to open the prostar using commend prompt, it gives a error message,
The Procedure entry poing __infinity could not be located in thr dll nutlibm4.dll
Any help to eliminate this error.
Old   September 4, 2006, 19:42
Default Re: prostar Error
TG
The first time you install star, you must install it from the CDrom. Only the CD contains the nutrcracker utilities required (and what you are missing). You can update from the web site to newer versions of STAR, but you cannot do a clean install. You need to call your user support and ask for a CDrom for Windows.
Old   September 9, 2006, 14:06
Kiran
If you are running on hummingbird exceed, try starting exceed manually and then start star-launch. It helped in my case when I first installed STAR.
Regards,
-Kiran
Thread Tools
Trackbacks are On
HyperMesh x ProStar Vinicius CD-adapco 2 January 21, 2009 16:30
Prostar doesn't starts Ruggero CD-adapco 2 July 8, 2007 16:53
PROSTAR Emmanuel Resch CD-adapco 7 August 1, 2006 08:37
Compiling Error in prostar Erika CD-adapco 7 November 22, 2004 05:13
where can i buy Prostar starCD Abdi Main CFD Forum 1 October 22, 2002 18:00
