Launder-sharma
Old   September 22, 2006, 10:01
Default Launder-sharma
Paul_fredric
I would like to program (Fortran) the launder& sharma model in starcd.
Can somebody help me ? which subroutines ?
Sorkep and vistur ?
All the best
Old   September 23, 2006, 10:55
Default Re: Launder-sharma
Sheila
As far as I remeber, I would say you need both. You need sorkep to include the f1, f2 etc in the production terms of k and e. You need vistur to implement the damping function fu in eddy viscosity.
Hope that helps.
Old   September 27, 2006, 02:26
Paul_fredric
Thank for your comments.
The main problem seems that in tne LS models, there are source terms in the k-e equations with spatial derivation of k and e which are not available in user subroutine commons
best
Old   September 27, 2006, 20:07
Sheila
Yes, you would need to calculate those using the various routines to calculate gradients etc... You will need the necessary subroutines allowing you to calculate these. Contacting STAR CD support system should help with those. Here are some to calculate velocity gradient and scalar gradient,
CALL VELGRD(UG,GU,S,CX,SB,NFONE,KEY,URO,URSI,VISTG,DENG ,TKG,
& VISCLAM,MON,ISTYP)
IF(LSWTCH(60))THEN
CALL GRSCGT
& (FI,10,NBMAX,NCTMAX,DFI,KEY,S,CX,NFONE,SB,MON,ISTY P)
ELSEIF(LSWTCH(33))THEN
CALL GRADSC(FI,10,NBMAX,NCTMAX,DFI,KEY,S,CX,NFONE,MON)
ELSE
CALL GRSCL2(10,FI,KEY,NBMAX,NCTMAX,DFI,CX,S,NFONE,MON,I STYP)
ENDIF
Old   October 2, 2006, 04:18
Default Re: Launder-sharma *NM*
Paul_fredric
Old   October 2, 2006, 04:20
Paul_fredric
Thank Sheila,
You give me some hope, about the possibility to calculate these gradient.
Sure I will contact the starcd support and maybe take a user subroutine formation
Old   October 31, 2006, 06:30
malika seddik bouchuicha
hello sir Iam Malika ; I want to know if you can send me some ofdocumentation about (StarCD , )also the VOF method.
Kato Launder UDF mike laudrap FLUENT 1 February 12, 2008 05:15
Gibson Launder Konstantinos Siemens 0 March 8, 2006 06:19
sanjib das sharma Jan Rusaas CFX 5 August 2, 2001 06:21
HELP URGENT: model turbulent LAUNDER SHARMA dory FLUENT 3 August 5, 2000 19:18
Launder & Sharma model in combusion case Richard Carroni Main CFD Forum 1 November 17, 1998 18:59
