-   CD-adapco (http://www.cfd-online.com/Forums/cd-adapco/)
-   -   can not run starcd 3.15 in windows XP? (http://www.cfd-online.com/Forums/cd-adapco/55627-can-not-run-starcd-3-15-windows-xp.html)
xhliu1 September 25, 2006 02:13
I have restalled my windows system,and starcd also been restalled,but when I begin to use it,there is some errors as bellow: Licensing problem:unable to list licensed features cannot connect to license server The server (lmgrd)has not been started yet,or the wrong port@host or license file hss been changed. Server name: localhost license path:......(directory which I install starcd in)
Flexlm error: -15,10. System Error:10061 "WinSock:Connection refused" For turther ......
what's the problem? and how can I solve it?
wish your quickly reply!! THank you very much!!
Anton Lyaskin September 25, 2006 06:53
Re: can not run starcd 3.15 in windows XP?
What's you licensing type - nodelocked or via FlexLM local server? Check LM_LICENSE_FILE system variable and make sure that FlexLM service is running for licensing via server. Try using lmtools.
ty November 3, 2006 12:46
Anton can you expand your explain please because I have the exactly same problem ..
