Home > Forums > CD-adapco
about shell auto-ignition
Old   October 19, 2006, 22:59
Default about shell auto-ignition
lizhihua
Hi all, I am trying to incorporate shell auto-ignition into my model of gasoline HCCI engine with a intake port. Since fresh charge is assumed to be well mixed in the intake port, no injection is involved.Contents of residuals(H2O,CO2 and N2)are set to be homogenous in the cylinder before intake valve opens. I use EBU standard, calculating the reactant distribution through "Transport". The problem is that no combustion occurred(judging from the pressure curve and the concentration of the products) even though radicals are generated.Moreover, radical2 is discovered in the intake port where I have't associate the chemical shceme. Totally confused! Dose anybody know why?Thanks for any help!
Old   October 29, 2006, 22:01
Default Re: about shell auto-ignition
DB
I am just guessing, since I dont know exactly how you setup the case. Did you associate the reaction scheme??
DB
Old   October 29, 2006, 22:08
lizhihua
Thanks first! Yes,I associated it with the cylinder material, and I guess that because of this the three radicals appeared. The problem is that there were no products of CO2 and H2O.
Old   October 29, 2006, 22:36
DB
So you are able to figure out the problem thats great
DB
Old   April 20, 2015, 18:02
sanjeet Limbu
sanjeetlimbu is on a distinguished road
I am also trying to do ignition for nheptane with air and argon inside the the cylinder in 2D asymmetric model.
I am getting no rise in temperature during compression and when it reach 700K+ it donot ignite..
Pl suggest how to get initial presuree rise for compression of volume and ignition after that
File Type: jpg fuel mole fraction and reaction progress.jpg (28.9 KB, 6 views)
sanjeetlimbu is offline   Reply With Quote
Thread Tools
Trackbacks are On
shell auto ignition cw CD-adapco 0 August 21, 2008 17:55
Auto-ignition model ECFM3Z Andrea CD-adapco 6 November 2, 2007 04:28
Auto-ignition models Colin Bosman CD-adapco 0 September 15, 2006 09:48
Shell Ignition Model Felix Main CFD Forum 0 February 10, 2006 01:40
Spontaneous combustion or auto ignition in FLUENT Seba FLUENT 3 December 9, 2005 00:06
