November 2, 2006, 19:23 |
Average velocity over a section of cells
I wanted to know if there is a quick way to find the average velocity of flow at a predefined section in a fluid flow. For example if we are interested in characterizing the flow from a hole or outlet we need the value of the average velocity over some cells. Can that be done without going in detail to the output file to figure the velocity at each face of the cells?
Thanks |
November 3, 2006, 02:12 |
Re: Average velocity over a section of cells
I think that you can use "Monitor Cell behavior" funtion in the output control panel.
And the *.ecd will report the value in each step. |
November 3, 2006, 19:23 |
Another way is to select those cells and load the post file and use summerize cset command
cset subs zone load,filename oper,getc,vmag,4 summerize cset DB |
November 4, 2006, 04:26 |
The other option is to create a section then use pscreat to generate shells representing the section then map the solution to the section and average in the same way that db suggested. This means you can get a true plane at a specific location, if you are using an unstructured grid the cell centers can vary a bit.
November 8, 2006, 17:53 |
Thanks a lot..
Display Modes | |
[OpenFOAM] Average Velocity | mrj301988 | ParaView | 4 | June 2, 2009 00:13 |
Velocity value at a Cross-Section??? | Umm.. | FLUENT | 6 | February 17, 2008 11:07 |
Area average of pressure on a section | Radhika | Siemens | 4 | April 4, 2007 19:05 |
Area and mass average values on a section | Peter N | Siemens | 3 | February 4, 2007 08:12 |
cross section average | Paul | FLUENT | 0 | April 12, 2006 12:30 |
