Home > Forums > CD-adapco
proam errors
Old   November 10, 2006, 23:37
Default proam errors
Radhika
Hi
I am trying to import a .dbs file into proam.
1. It gives me an error that the Database does not exist. 2. prostar says the model has no errors. When I am trying to import the same model proam says non manifold errors. 3. proam did not generate a volume mesh even when I check the close free edges and fill holes option in the mesh wizard.
Can someone help please.
Old   November 12, 2006, 05:33
Default Re: proam errors
Ben
1. Are you selecting the right dbs number? 2. Pro-STAR doesn't care about non-manifold edges, pro-am does 3. Don't use the mesh wizard then....
Old   November 13, 2006, 05:56
Siddharth
After loading the correct .dbs file, if you are unable to generate the volume mesh from 2D, saying something like "No-Manifold topology". It means there is some problem with your 2D mesh. It can be bad orientation of cell vertices, or something else.
You should first check with the check surface tool, putting all the options on. For non-manifold topology, shell orientation etc. Many times orientation problem gives you negative volume problem or non manifold topology problem. You should first rectify these problems using the repair tools in Proam. And you should make sure there is no manifold problem, before going for volume mesh generation.
Hope it will help.
good luck.
Thread Tools
Trackbacks are On
Proam: Assembly Bala CD-adapco 1 March 15, 2008 21:21
Help proam yogesh CD-adapco 8 February 16, 2006 06:19
proam issue novice CD-adapco 1 April 21, 2005 02:04
proam sankar CD-adapco 0 February 23, 2005 05:58
Proam cpmatches Erika CD-adapco 3 November 8, 2004 20:21
