Visualising an interface between two continuums
Old   November 14, 2006, 09:34
Default Visualising an interface between two continuums
Rich
Hi there,
I'm an engineering student and I am using STAR CCM+ (version 1.08.015) to visualise the flow of oil in a sump which I have designed. I am trying to achieve a simple visualisation for the angle of the oil when gravity models are applied in several directions.
I have set up the model so that there are 2 continuums (air and oil) assigned to two regions. I have also set the gravity models with the appropriate values.
I have set up an interface between two faces of the different regions but this always remains static no matter what I do to the simulation. How do I actually get a scene which visualises the interface between the air and the oil, showing the effects of the gravity models? (i.e. i am expecting to see the oil squashed up at the back and to one side of the sump due to the applied gravity forces)
I hope you can understand what I am getting at here! Thanks in advance.
I apologise if this seems simple but I have had to learn the program without any tuition!
2d interface Rogerio Fernandes Brito CFX 2 July 26, 2008 12:25
[OpenFOAM] Visualising molecular dynamics results santos ParaView 2 July 25, 2008 11:47
About Interface BC Philip FLUENT 0 January 3, 2008 01:51
interface braket FLUENT 1 November 15, 2005 01:58
Interface abigaille Gilibert FLUENT 1 July 22, 2002 16:00
