November 16, 2006, 12:35 |
Errors writing problem file.
Can anyone help me with the following error? When I try to write the problem file in prostar, the program quits, and I get the following error message:
? System Error: ? Bad file number ? CLOSE(UNIT=7,... All I can think of is its either a problem with my installation, or with the version of prostar I'm using. The model was initially created using prostar version 3.26.039, only I've only been able to install 3.26.004. I've tried re-installing prostar, still have the same problem. |
November 16, 2006, 16:41 |
Re: Errors writing problem file.
windows, linux or unix system? Also, even with patches its generally not a good idea to go backwards - I wouldn't create a model in patch 39 and resume in 4. I don't think that it is the problem though.
November 16, 2006, 17:13 |
I'm running the model on a windows system
November 19, 2006, 10:11 |
In addition to reinstalling prostar did you also remove and reinstall the MKS (Nutcracker) systems? I suspect its some corrupt interaction between those two.
Display Modes | |
UDF for writing txt. file | manu | FLUENT | 2 | December 13, 2007 07:19 |
Writing file problem | vinz | OpenFOAM Running, Solving & CFD | 5 | February 1, 2007 06:03 |
Writing to a file | Mike | FLUENT | 6 | June 19, 2005 00:57 |
writing User file | sam | Siemens | 1 | May 31, 2005 16:10 |
Writing ngeom file | Luca D | Siemens | 2 | March 30, 2004 06:24 |
